Solubility Product Constant Question
In summary: So, if we substitute in the new concentrations and do the same thing to find equilibrium concentrations, we get...0.1[sup2[/sup]*0.06 > Kso, so there was a precipitate of 0.06 moles.
startle101
The solubility-product constant for K2PdCl6 is 6.0 x 10^ -6 (K2PdCl6 ---> 2K+ + PdCl6 2-). What is the K+ concentration of a solution prepared by mixing 50.0 mL of 0.200 M KCl with 50.0 mL of 0.100M PdCl6(2-)?
My Approach (thus far):
1) get mmol of KCl and PdCl6(2-) and get difference of them for excess mmol (of what though?).
2) I'm not really sure what to do from there without knowing which would be in excess...My hunch is to solve whatever is in excess to similar terms to get concentration of K+.
Anyways, this questions has had me scratching my head for a few days. Thanks for all the help I get!
- Find the new concentrations.
- If the solubility product is saturated by incorporating the two concentrations into the solubility product equation then use the equation to find the amount of precipitate formed.
-From this deduce the actual saturation concentrations of the K + cations.
You see, that's my ultimate confusion - the first step.
I will show you how I'm doing everything mathematically below
0.200 M KCl x .05 L = .01 mol KCl
0.100 M PdCl6(2-) x .05 L = .006 mol PdCl6(2-)
Now I divide each by total volume ( 50 mL + 50 mL = 100 mL)
.01 mol KCl/.100 L = 0.1 M KCl x 2 = 0.2 M KCl (because of stoichiometric factor from equation above)
.006 mol PdCl6(2-)/.100 L = 0.06 M PdCl6(2-)
So, I have the new concentrations...My goal is to get [K+] though; however, unfortunately, this is where I'm stuck...
I could substitute [PdCl6(2-)] = 2 [K+]
which would then end up as...
2 [K+][K+]^2 = 6.0 x 10^-6
where [K+] = 0.0144 M
Is that the correct approach? How would you correct it?
startle101 said:
0.100 M PdCl6(2-) x .05 L = .006 mol PdCl6(2-)[/quot]e
? Why 6?
[K+] = 0.1
[PdCl62-] = 0.05
0.1[sup2[/sup]*0.05 > Kso, so obviously there was a precipitate.
Now, you know that some of the K+ was removed from the solution in the form of precipitate. Assume it was x moles. That means that equilibrium concentration of K+ is
[tex]\frac {0.05L*0.2M-2x} {0.1L}[/tex]
do the same thing to find concentration of PdCl62-. Write formula for Kso, solve for x.
FAQ: Solubility Product Constant Question
What is the solubility product constant (Ksp)?
The solubility product constant, also known as Ksp, is a measure of the degree to which a compound can dissolve in water to form a saturated solution. It is the equilibrium constant for the dissociation of a solid compound into its ions in a solution.
How is the solubility product constant calculated?
The solubility product constant is calculated by multiplying the equilibrium concentrations of the dissociated ions in a saturated solution. For example, if a compound A2B has a stoichiometric equation of A2B ⇌ 2A+ + B-, the Ksp would be [A+]^2[B-]. The values for the concentrations of the ions can be found through experimentation or from a solubility table.
What factors affect the solubility product constant?
The solubility product constant can be affected by temperature, pressure, and the presence of other ions in the solution. Generally, an increase in temperature or pressure will increase the solubility product constant, while the presence of other ions can cause a shift in the equilibrium and therefore affect the value of Ksp.
What does a high solubility product constant indicate?
A high solubility product constant indicates that a compound is highly soluble in water and can form a saturated solution easily. This means that the compound is more likely to dissociate into its ions and remain in solution. On the other hand, a low solubility product constant indicates that the compound is less soluble and may not form a saturated solution.
How is the solubility product constant used in chemistry?
The solubility product constant is used to predict the solubility of a compound in water, to determine the concentration of ions in a saturated solution, and to calculate the molar solubility of a compound. It is also used in equilibrium calculations to determine the direction of a reaction and to predict the formation of precipitates.
