Solve De Moivre's Theorem for z^10
  • Thread starter jwxie
  • Tags
    Theorem
In summary, we are asked to find z^10 where z=1-i. Using the formula |z|= \sqrt{(1)^{2}+{-1}^2}, we find that the magnitude of z is √2 and the angle is -45 degrees. We then use the DeMoivre's theorem and the formula a=|z|cos(\theta), b=|z|sin(\theta) to find that z^10=-32i. There is no need to add 2pi when expanding z^n according to DeMoivre, and the small quantity obtained when evaluating the cosine is due to the approximation used by the calculator. Another way to solve this problem without using angles is to simplify (1
jwxie
282
Let z = 1 − i. Find z^10.
[itex]|z|= \sqrt{(1)^{2}+{-1}^2}[/itex]
[itex]a=|z|cos(\theta )[/itex], [itex]b=|z|sin(\theta )[/itex]
and we find that [itex]\theta [/itex] = -pi/4 or 7*pi/4 (Accoridng to this, it is in the fourth quadrant )
[PLAIN]http://dl.dropbox.com/u/14655573/latex/dem.PNG
Why do we add 2*pi at the end? And moreover, if I use 7*pi/4, I notice that the cosine will vanish to 1.2e-12 close to zero, but are we really allowed to ignore that vanish value, and instead write -32i ?
Thanks!
Thanks!
How are you getting 1.2 * 10-12? That sounds like a calculator rounding error for cos(7π/4 * 10), which IS equal to 0.
There is no requirement to add 2pi when expanding z^n according to DeMoivre. Line 3 in the attachment evaluates to the correct result. The small quantity you obtained when evaluating the cosine is due to the approximation your calculator uses to calculate values for this function. Remember, cos(x) = 0 for all values of x = (2k+1)* pi/2 and k is any integer.
Hi Char. Limit.
I guess you are right. That's what I am wondering too... since that would definitely give zero. Sometime I do stuff on the calculator just to simplify things.
and thanks SteamKing. You both are right.
So I guess the whole purpose of adding 2pi is just to simplify the expression. (actually -5pi/2 will be fine).
TI-83 I am using. Interesting, huh?
Thanks!
|z| = sqrt(2) and arg(z) = -45 degrees. We have |z^10| = 2^5 = 32 and the angle of z^10 is = 10*arg(z) = -450 degrees. In the standard interval [-180,180] degrees, this angle is -90 degrees, because 450 mod (360) = 90. So arg(z^10) = -90 degrees, hence z^10 = -32i.
RGV
Adding [itex]2\pi[/itex], which obviously doesn't change the angle, to [itex]-5\pi/2[/itex] changes the form to [itex]-\pi/2] which is easily seen to be "straight down".
There is an easy way (without angles) to get the result of this problem:
(1-i)10=((1-i)2)5,
As i*i=-1,
(1-i)2=-2i,
so (1-i)10=(-2)5 i5=-32i
ehild
FAQ: Solve De Moivre's Theorem for z^10
What is De Moivre's Theorem?
De Moivre's Theorem is a mathematical formula that relates complex numbers (numbers with both real and imaginary parts) to trigonometric functions. It states that for any complex number z and any positive integer n, (cos⁡θ + i sin⁡θ)^n = cos⁡(nθ) + i sin⁡(nθ).
How do you solve De Moivre's Theorem for z^10?
To solve De Moivre's Theorem for z^10, we can rewrite the formula as (cos⁡θ + i sin⁡θ)^10 = cos⁡(10θ) + i sin⁡(10θ). Then, we can use the binomial expansion to simplify the right side of the equation. This will give us a new complex number in the form a + bi, where a and b are real numbers.
What is the significance of solving De Moivre's Theorem for z^10?
Solving De Moivre's Theorem for z^10 allows us to find the 10th power of a complex number without having to perform multiple calculations. This can be useful in a variety of mathematical and scientific applications, such as in electrical engineering, signal processing, and physics.
Can De Moivre's Theorem be used for numbers other than complex numbers?
No, De Moivre's Theorem is specifically for complex numbers. It does not apply to real numbers or other types of numbers.
Are there any limitations to using De Moivre's Theorem?
De Moivre's Theorem is limited to calculating powers of complex numbers. It cannot be used to solve other types of equations or problems. Additionally, it only works for positive integer powers, so it cannot be used for fractions or negative powers.
