Solve Flow Rate Problem: 9 kW Shower
In summary, the student is trying to estimate the flow rate of water in a shower with a power rating of 9 kW. They are unsure of which equation to use and if they need to make assumptions about temperature and other quantities. After some discussion, they determine that Q = m * c * delta T is the best approach and estimate the flow rate to be 0.107 kg/s, which seems reasonable based on a 1 liter container filling in 9 seconds. They also clarify the dimensions of m and show that the equation balances.
tweety1234
112
a) A student taking a shower notices that the power rating of the shower is 9 kW. Estimate the flowrate of the water.
I think I have to use the equation [tex] Q = m c \delta T [/tex]
However I have not beeen given any temperature or anything, like that, or the mass? How would I do this question? Is there any other formula to use? Am I just mean to assume an temperature?
Thank you.
It says "estimate", so you're probably meant to make reasonable guesses at things like that. Suppose the temperature of the room is 20 degrees, the temperature of the water is maybe 50 degrees. You'll need to make similar guesses for some of the other quantities involved too.
okay,
so Q = 9KW
[tex] c = 4.198 KJ kg^{-1} K^{-1} [/tex]
T = 50C - 20C = 30C
so do I just solve for 'm'? Is that the flow rate?
Yes, that is probably the best approach.
I was thinking that you would also account for the fact that some of the shower's power is spent giving the water kinetic energy and you would need to make a guess at the pressure with which it comes out. Now that I look more closely at it, though, I think that effect is probably negligible compared to the heating.
Hello, Just wondering should I change KW to Watts?
cause when I do the calculation with 9KW I get
[tex] 9 = m \times 4.198 \times 20 [/tex]
[tex] m = 0.086 [/tex] quite a small flow rate?
Also having a few troubles with the units, if I am calculating flow rate it should be kg/s
but if I do some dimensional analysis on this equation I just get mass ?
I know that [tex] W = \frac{J}{s} [/tex]
so does [tex] KW = \frac{kJ}{s} [/tex] ?
[tex] \frac{KJ}{s} = m \frac{KJ}{kg K} K [/tex]
[tex] \frac{KJ}{s} = \frac{m KJ}{kg} [/tex]
I think you did the arithmetic wrong there. Firstly, you're now using 20 degrees for the temperature change? I think that may be too low, but okay.
9/(4.198*20)=0.107
I think this is about right, consider if you held a 1 litre container under a shower, then with this flow rate, it would take 9 seconds to fill. That sound reasonable to me.
As for the dimensions, there is no problem. Consider that the dimensions of m here are kg/s because m is not a mass, it is how much mass passes every second. With this in mind, the equation you wrote balances.
FAQ: Solve Flow Rate Problem: 9 kW Shower
What is flow rate?
Flow rate is the amount of fluid that passes through a given area in a specific amount of time. It is typically measured in liters per minute (LPM) or gallons per minute (GPM).
How do you calculate flow rate?
To calculate flow rate, you need to know the volume of fluid passing through a given area in a specific amount of time. This can be calculated by dividing the volume by the time. For example, if a shower has a flow rate of 9 liters per minute and you take a 5 minute shower, the total volume of water used would be 45 liters.
What is the flow rate of a 9 kW shower?
The flow rate of a 9 kW shower will depend on the specific showerhead and plumbing system being used. However, on average, a 9 kW shower will have a flow rate of approximately 9 liters per minute.
How does the power of a shower affect the flow rate?
The power of a shower, measured in kilowatts (kW), directly affects the flow rate. The higher the power, the faster the water will flow through the showerhead, resulting in a higher flow rate. In the case of a 9 kW shower, the flow rate will be faster than a lower powered shower.
What factors can affect the flow rate of a shower?
There are several factors that can affect the flow rate of a shower, including the power of the shower, the size and design of the showerhead, and the plumbing system. Other factors such as water pressure and any blockages or restrictions in the pipes can also impact the flow rate.
