ultimateguy
- 125
- 1
The homogeneous Helmholtz equation
[tex]\bigtriangledown^2\psi+\lambda^2\psi=0[/tex]
has eigenvalues [tex]\lambda^2_i[/tex] and eigenfunctions [tex]\psi_i[/tex]. Show that the corresponding Green's function that satisfies
[tex]\bigtriangledown^2 G(\vec{r}_1, \vec{r}_2)+\lambda^2 G(\vec{r}_1, \vec{r}_2)=-\delta(\vec{r}_1-\vec{r}_2)[/tex]
may be written as
[tex]G(\vec{r}_1, \vec{r}_2)=\sum_{i=1}^{\infty}\frac{\psi_i(\vec{r}_1)\psi_i(\vec{r}_2)}{\lambda^2_i-\lambda^2}[/tex]
[tex]\int(\psi \bigtriangledown^2 G-G\bigtriangledown^2 \psi) d\tau_2=\int(\psi \bigtriangledown G-G\bigtriangledown\psi) d\sigma[/tex]
I'm using Arfken's Mathematical methods for physicists, and it isn't very good at explaining the examples it uses. I just need some kind of jump start to get me going. Do I need to use the equation in the relevant equations section?
