Solving a differential equation in classical mechanics
In summary: Thanks for your time.In summary, the problem involves a particle of mass m subject to a force F(v)=-bv^2. The initial position is zero and the initial speed is v_0. The task is to find x(t). The attempt at a solution involved defining Q=-b/m and setting {\ddot{x}}=Q{\dot{x}}^2. Further substitutions were made and a guess was made for u, which led to an incorrect solution. A more reasonable solution was found by separating variables and integrating. The resulting answer is x(t)=\frac{m}{b}ln(1 + V_o \frac{b}{m}t). There was also some confusion and discussion about the assumptions made and the
Shing
144
A particle of mass m is subject to a force
[tex]F(v)=-bv^2[/tex]
The initial position is zero, and initial speed is [itex]v_o[/itex] Find x(t)
for convenience's sake, define
[tex]Q=-\frac{b}{m}[/tex]
therefore,
[tex]{\ddot{x}}=Q{\dot{x}}^2[/tex]
Let
[tex] u=\dot{x}[/tex]
[tex]\dot{u}=Qu^2[/tex]
then I just made a guess, not hard to see
[tex]u=-\frac{1}{Qt}[/tex]
therefore
[tex]\dot{x}=\frac{-1}{Qt}[/tex]
intergrate both side, and define x(1)=0
[tex]\int_{x(1)}^{x'} dx=\int_{1}^{t'}\frac{-dt}{Qt}[/tex]
therefore
[tex]x'-x(1)=\frac{1}{Q}(In|1|-In|t'|)[/tex]
implies
[tex]e^{x}=t^\frac{m}{b}[/tex]
so
1.)is it the solution? or is there another better solution?
actually, I really have a problem. As it is a not bounded function, somehow I think there might by another more reasonable answer, as it makes no sense when t is approaching to zero.
2.) what physical meaning is it when t is approaching 0?
thanks!
i guess you got it wrong, I'm not good at mathematics, but i suppose you did something not right when you wrote that u = -(1/Qt), which is not true. Cause u as you wrote it is speed and here the problem you mentioned comes out - when t = 0, speed is infinity, but in problem statement it is said that at t = 0, speed has some defined value. I think you could do this problem first by finding velocity as function of time, and then coordinate as function of time - you will need to do integration twice. Just write:
m(dv/dt) = -bv^2
get (dt) on the ledt side, and v^2 on the left, and then integrate over reasonable interval (from say v0 to v, and t0 = 0 to t). Hope this will help you a bit ;]
Are you sure the question reads "t approaching 0"? How can t approach 0 if t starts at 0?
If you define define x(1)=0 as you said you were doing, simplifying your solution gives [tex]x}=-\ln{t}[/tex],
The way you started is somewhat messy.
Instead of lots of substitutions, let the acceleration be [tex]a=v\frac{dv}{dx}[/tex], then integrate and see what happens. :wink:
Do you have an answer to work towards?
therefore,
Let
therefore
You solved the differential equation incorrectly. Instead of guessing, use separation of variables to find the complete solution.
The answer I got when I worked it out is
[tex]x(t)=\frac{m}{b}ln(1 + V_o \frac{b}{m}t)[/tex]
I could be wrong though, but at least it's something to work towards.
well I got the same answer as Maybe Memorie ;]
Thank everybody ! Somehow I make a much more reasonable answer that is same as Maybe_Memorie =)
[tex]
v\frac{dv}{dx}=Qv^2[/tex]
assuming v>0 for all t, and integrate both sides
[tex]
\int_{v_0}^{v'}\frac{dv}{v}=\int_{0}^{t'}Qdt[/tex]
[tex]
In\frac{v}{v_0}=Qx[/tex]
implies
[tex]
e^{Qx}=\frac{v}{v_0}[/tex]
[tex]
v_0\int_{0}^{t'}dt=\int_{0}^{x'}\frac{dx}{e^{Qx}}[/tex]
and after some calculation (just too lazy to type it here =P)
[tex]
However, I have a question here for Math.
Does the below definition still works even
[tex]\int_{b}^{a}f(x)dx=F(a)-F(b)[/tex]
F(x) is unbounded? From Apostol's book, the function must be bounded, such that its integral exists. But can the definite integral exist? Thanks! (sorry, I haven't read it to the section discussing about it)
besides, is it why that my first approach false?
[tex]
u=-\frac{1}{Qt}
[/tex]
in which, I assume t>0, whereas, in fact, t can be and starts from 0.
but what if I only consider t>0?
will the equation works well for t>0 (obviously not, just doesn't make the physical sense, but why it fails? is it because [itex]
u=-\frac{1}{Qt}
[/itex] in which the fact that t is not zero is a false assumption, by the logic, a F-if can lead to a F-then, even if the logic is right here?)
Like I said yesterday, when you claimed u=-1/(Qt), you didn't solve the differential equation correctly. If you separate variables and integrate, you'll get the correct answer.
Thanks, but why if I claimed u=-1/(Qt), I won't solve the differential equation correctly?
Even if I check it back, which matches the conditions?
Cause dx/dt is not equal to -1/(Qt), why do you think it is?
Have you actually solved the differential equation the way I've suggested? If you do that, it's pretty clear why your guess didn't work for this problem.
um... actually, I have done the calculation at two other approaches that arrive the expected answer.
however, sorry for my lousy way of asking questions
I mean I just don't understand.
[tex] \dot{x}=-\frac{1}{Qt}
[/tex]
[tex] \Rightarrow \ddot{x}=\frac{1}{Qt^2}
[/tex]
and
[tex] Q\dot{x}^2=\frac{1}{Qt^2}
[/tex]
so why [itex] \dot{x}[/itex] can't be [itex]-\frac{1}{Qt}[/itex]?
I compared the two dx/dt
a.)the "guess work appraoch", but with a unreasonable answer:
[tex]\dot{x}=\frac{b}{mt}
[/tex]
b.)the "separating the variables appraoch" but with a much more reasonable answer:
[tex]\dot{x}=\frac{1}{\frac{1}{v_0}+\frac{b}{m}t}
[/tex]
And here is my opinion:
For a.), during the calculation: I assumed: 1.) t will never be zero. So whenever it comes to t=0, contradictions appear. it is simply contradicted to the whole question WHEN t=0.
1.)As it is a force function of speed, if given [itex]v_0=0[/itex], then it will NEVER move at all. However, the equation tells that there is such a [itex]\ddot{x}[/itex] independent of initial velocity.
still lots of questions in my head... It takes some times to manage them at once
After you separate the variables, you have
[tex]\frac{dv}{v^2} = -\frac{b}{m}dt[/tex]
When you integrate that, what do you get for v(t)?
a.)the one with a unreasonable answer:
[tex]\dot{x}=-\frac{1}{Qt}
[/tex]
b.)the one with a much more reasonable answer:
[tex]\dot{x}=-\frac{v_0}{1-{V_0}Qt}=-\frac{1}{\frac{1}{v_0}-Qt}
[/tex]
Note that the only difference between the two solutions is the 1/v0 term in the denominator. It has to be there so the solution can satisfy the initial condition. Your guessed solution satisfies the differential equation, but it's for an initial condition different than the one given in the problem.
When you solve a differential equation, you don't get just one solution; you get a family of solutions because of the arbitrary constant of integration. Then you use the initial condition to determine what that constant is equal to -- which is what I was trying to get you to do -- thus choosing one solution out of the family of solutions.
FAQ: Solving a differential equation in classical mechanics
What is a differential equation in classical mechanics?
A differential equation in classical mechanics is a mathematical equation that describes the relationship between the position, velocity, and acceleration of a particle or system in motion. It is based on Newton's laws of motion and is used to model and predict the behavior of objects in motion.
Why is solving a differential equation important in classical mechanics?
Solving a differential equation is important in classical mechanics because it allows us to determine the exact position, velocity, and acceleration of a particle or system at any given time. This is essential in understanding and predicting the behavior of objects in motion, such as planets, projectiles, and pendulums.
What methods are used to solve differential equations in classical mechanics?
There are several methods used to solve differential equations in classical mechanics, including separation of variables, variation of parameters, and the use of Laplace transforms. Each method has its own advantages and is used depending on the complexity of the equation and the type of solution required.
Can differential equations be solved analytically or numerically?
Yes, differential equations in classical mechanics can be solved both analytically and numerically. Analytical solutions involve finding an exact mathematical expression for the solution, while numerical solutions use computational methods to approximate the solution. The choice of method depends on the complexity of the equation and the precision required.
What are the applications of solving differential equations in classical mechanics?
Solving differential equations in classical mechanics has many practical applications, including predicting the motion of objects in space, designing and testing mechanical systems, and understanding the behavior of fluids and gases. It is also used in various fields such as engineering, physics, and astronomy to model and analyze complex systems and phenomena.
