Solving Dependence of Velocity on Time
In summary, the conversation involves a person seeking help with changing the dependence from velocity to time in a problem involving equations with terms on both the left and right hand sides. They discuss rearranging the terms and potentially using the Bernoulli equation.
fer Mnaj
34
Member warned that some effort must be shown
Given the acceleration as a function of speed a = −kv (v - v_c) (a) Find an expression for speed as a function of time. (b) How would it look a sketch of velocity as a function of time for initial velocities v_o greater than v_c and less than v_c?
a = −kv (v - v_c)
I could use some help with this problem. I am having trouble finding how to change the dependence from velocity to time in a).
fer Mnaj said:
Im having trouble finding how to change the dependence from velocity to time in a).
What have you tried?
Hi, so far
a= dv/dt
so
dv/dt=−kv^ 2+(kv_c)v
dv/dt−(kvc)v=−kv^ 2
fer Mnaj said:
so far
a= dv/dt
so
dv/dt−(kvc)v=−kv^ 2
So what kind of equations are these? (Try moving all of the terms to the LHS and making the RHS zero. What kind of equation do you have?)
whats RHS and LHS??, I think its bernoulli, isn't it?
fer Mnaj said:
whats RHS and LHS?
Right Hand Side and Left Hand Side.
fer Mnaj, thanks.
@fer Mnaj , if the rearrangement @PeterDonis suggests does not help you, try rearranging it so that the dt is on one side and all the references to v are on the other.
Likes Chestermiller and hutchphd
FAQ: Solving Dependence of Velocity on Time
What is the dependence of velocity on time?
The dependence of velocity on time refers to the relationship between an object's velocity and the amount of time it takes to travel a certain distance. This relationship is usually represented by a graph, with time on the x-axis and velocity on the y-axis. The slope of the graph represents the object's acceleration.
How do you solve for the dependence of velocity on time?
To solve for the dependence of velocity on time, you will need to have data on an object's velocity at different points in time. This data can be used to create a graph, and the slope of the graph can be calculated to determine the object's acceleration. You can also use the equation v = u + at, where v is final velocity, u is initial velocity, a is acceleration, and t is time.
What factors can affect the dependence of velocity on time?
The dependence of velocity on time can be affected by factors such as the object's initial velocity, the object's mass, and external forces acting on the object (such as friction or air resistance). These factors can cause the object's velocity to change over time, resulting in a non-linear graph.
Why is understanding the dependence of velocity on time important?
Understanding the dependence of velocity on time is important in many fields, including physics, engineering, and even sports. It allows us to analyze and predict the motion of objects, which is crucial for designing and building structures, vehicles, and machines. It also helps us understand the principles behind sports techniques, such as how a baseball pitcher can throw a curveball.
How can I apply the knowledge of solving for the dependence of velocity on time?
The knowledge of solving for the dependence of velocity on time can be applied in various real-life situations. For example, it can be used to calculate the time it takes for a car to reach a certain speed, or the distance a basketball player can jump based on their acceleration. It can also be used to analyze the motion of planets and satellites in space. Overall, understanding this concept can help us better understand the world around us and make accurate predictions about the behavior of moving objects.
