Solving for the t in the Integral of 1/sqrt(9+t^2) dt
  • MHB
  • Thread starter karush
Thank you very much!In summary, $\int_{0}^{4}\frac{1}{\sqrt{9+t^2}} \,dt$ can be reduced to $\ln|t + \sqrt{9 + t^2}| + C$ through the use of conjugates and the substitution $u = t + \sqrt{9 + t^2}$. This can be generalized to $\int \frac{1}{\sqrt{\lambda + t^2}}\, dt = \ln|t + \sqrt{\lambda + t^2}| + C$.
karush
MHB
3,269
The book said the and was 2 but the TI said it was $\ln\left({3}\right)$
I tried using $$u=\sqrt{9+t^2}$$ but for$$\int_{}^{}\frac{1}{\sqrt{9+t^2}} \,dt$$
I got $\ln\left({\sqrt{9+t^2}}+t\right)$
Where does the $t$ come from
According to W|A, this definite integral is:
\(\displaystyle \arsinh\left(\frac{4}{3}\right)=\ln(3)\)
Sorry I posted before finishing
But on the indefinite integral where does the $t$ come from?
Use the relation $$\cosh^2(x) - \sinh^2(x) = 1$$ by using the substitution $t=3\sinh(x)$. You obtain $dt = 3 \cosh(x) \, dx$ and therefore $$\int_0^4 \frac{1}{\sqrt{9+t^2}} \, dt = \int_0^{\sinh^{-1} (4/3)} \, dx = \operatorname{arcsinh} \left( \frac{4}{3} \right).$$ To see this is equal to $\ln(3)$, let $$\operatorname{arcsinh} \left( \frac{4}{3} \right) = \theta.$$ Then $$\sinh(\theta) = \frac{e^{\theta} - e^{-\theta}}{2} = \frac{4}{3}.$$ Multiply it by $e^{\theta}$ and simplify. You'll get $$e^{2 \theta} - \frac{8}{3} e^{\theta} -1=0.$$ Finding the root of this second degree polynomial you'll find $e^{\theta} = 3$, therefore $\theta = \ln(3)$.
$\displaystyle \begin{align*} \int{ \frac{1}{\sqrt{9 + x^2}}\,\mathrm{d}x} &= \int{ \frac{1}{\sqrt{9 + \left[ 3\tan{(t)} \right] ^2}}\,3\sec^2{(t)}\,\mathrm{d}t} \textrm{ after substituting } x = 3\tan{(t)} \implies \mathrm{d}x = 3\sec^2{(t)}\,\mathrm{d}t \\ &= \int{ \frac{3\sec^2{(t)}}{\sqrt{9 + 9\tan^2{(t)}}}\,\mathrm{d}t} \\ &= \int{ \frac{3\sec^2{(t)}}{\sqrt{9\sec^2{(t)}}} \,\mathrm{d}t} \\ &= \int{ \frac{3\sec^2{(t)}}{3\sec{(t)}}\,\mathrm{d}t } \\ &= \int{\sec{(t)}\,\mathrm{d}t} \\ &= \int{ \frac{1}{\cos{(t)}}\,\mathrm{d}t} \\ &= \int{\frac{\cos{(t)}}{\cos^2{(t)}}\,\mathrm{d}t} \\ &= \int{ \frac{\cos{(t)}}{1 - \sin^2{(t)}}\,\mathrm{d}t} \\ &= \int{ \frac{1}{1 - u^2}\,\mathrm{d}u} \textrm{ after substituting } u = \sin{(t)} \implies \mathrm{d}u =\cos{(t)}\,\mathrm{d}t \\ &= \int{ \frac{1}{\left( 1 - u \right) \left( 1 + u \right) }\,\mathrm{d}u} \\ &= \int{ \frac{1}{2 \left( u + 1 \right) } - \frac{1}{2\left( u - 1 \right) } \,\mathrm{d}u} \\ &= \frac{1}{2} \ln{ \left| u + 1 \right| } - \frac{1}{2} \ln{ \left| u - 1 \right| } + C \\ &= \frac{1}{2} \ln{ \left| \frac{ u + 1}{u - 1} \right| } + C \\ &= \frac{1}{2} \ln{ \left| \frac{\sin{(t)} + 1}{\sin{(t)} - 1} \right| } + C \\ &= \frac{1}{2} \ln{ \left| \frac{\left[ \sin{(t)} + 1 \right] ^2}{ \left[ \sin{(t)} - 1 \right] \left[ \sin{(t)} + 1 \right] } \right| } + C \\ &= \frac{1}{2}\ln{ \left| \frac{\sin^2{(t)} + 2\sin{(t)}\cos{(t)} + 1}{\sin^2{(t)} - 1} \right| } + C \\ &= \frac{1}{2} \ln{ \left| \frac{\sin^2{(t)} + 2\sin{(t)}\cos{(t)} + 1}{-\cos^2{(t)}} \right| } + C \\ &= \frac{1}{2} \ln{ \left| -\tan^2{(t)} - 2\tan{(t)} - \sec^2{(t)} \right| } + C \\ &= \frac{1}{2} \ln{ \left| -\tan^2{(t)} - 2\tan{(t)} - \left[ 1 + \tan^2{(t)} \right] \right| } +C \\ &= \frac{1}{2}\ln{ \left| -2\tan^2{(t)} - 2\tan{(t)} - 1 \right| } +C \\ &= \frac{1}{2} \ln{ \left| 2\tan^2{(t)} + 2\tan{(t)} + 1 \right| } +C \\ &= \frac{1}{2} \ln{ \left| 2 \left( \frac{x}{3} \right) ^2 + 2 \left( \frac{x}{3} \right) + 1 \right| } +C \\ &= \frac{1}{2} \ln{ \left| \frac{2x^2}{9} + \frac{2x}{3} + 1 \right| } +C \\ &= \frac{1}{2} \ln{ \left| \frac{2x^2 + 6x + 9}{9} \right| } +C \\ &= \ln{ \left| \frac{\sqrt{2x^2 + 6x + 9}}{3} \right| } + C \end{align*}$
PHEW!
Wow. That is truly worthy of the name tour-de-force!
Hi karush,
A main reason that $t$ is present is because $9$ is the product of the conjugates $\sqrt{9 + t^2} + t$ and $\sqrt{9 + t^2} - t$. Let me explain more.
Since $(\sqrt{9 + t^2} + t)(\sqrt{9 + t^2} - t) = (9 + t^2) - t^2 = 9$, $$\int \frac{dt}{\sqrt{9 + t^2}}$$
$$= \frac{1}{9} \int \frac{(\sqrt{9 + t^2} + t)(\sqrt{9 + t^2} - t)}{\sqrt{9 + t^2}} \, dt$$
$$=\frac{1}{9} \int \left(1 + \frac{t}{\sqrt{9 + t^2}}\right) (\sqrt{9 + t^2} - t)\, dt$$
$$= \int \left(1 + \frac{t}{\sqrt{9 + t^2}}\right) \frac{1}{\sqrt{9 + t^2} + t}\, dt$$
Now let $u = t + \sqrt{9 + t^2}$. Then $du = (1 + t/\sqrt{9 + t^2})\, dt$. So the last integral becomes $\int \frac{du}{u} = \ln|u| + C = \ln|t + \sqrt{9 + t^2}| + C$. Thus
$$\int \frac{1}{\sqrt{9 + t^2}}\, dt = \ln|t + \sqrt{9 + t^2}| + C.$$
Using this method, you may deduce more generally
$$\int \frac{1}{\sqrt{\lambda + t^2}}\, dt = \ln|t + \sqrt{\lambda + t^2}| + C.$$
Wow, that was a LOT of help
FAQ: Solving for the t in the Integral of 1/sqrt(9+t^2) dt
What is the meaning of "Int of 1/sqrt(9+t^2) dt"?
The expression "Int of 1/sqrt(9+t^2) dt" represents the definite integral of the function 1 over the square root of 9 plus t squared, with respect to the variable t.
How do you calculate the value of "Int of 1/sqrt(9+t^2) dt"?
To calculate the value of "Int of 1/sqrt(9+t^2) dt", you can use the substitution method or integration by parts. You can also use a graphing calculator or software to compute the integral numerically.
What is the domain of the function 1/sqrt(9+t^2)?
The domain of the function 1/sqrt(9+t^2) is all real numbers except t = 3 and t = -3. This is because the function is undefined at these values due to division by zero.
What is the significance of the expression "Int of 1/sqrt(9+t^2) dt" in science?
The expression "Int of 1/sqrt(9+t^2) dt" is often used in physics and engineering to calculate the displacement or distance traveled by an object with constant acceleration. It can also be used to find the area under a curve in statistics and economics.
How does the value of "Int of 1/sqrt(9+t^2) dt" change as t approaches infinity?
As t approaches infinity, the value of "Int of 1/sqrt(9+t^2) dt" approaches a finite value of π/2. This means that the area under the curve of the function 1/sqrt(9+t^2) is bounded, and does not continue to increase indefinitely.
