Solving integral in complex analysis
In summary, Dick forgot to take into account that when z is not 1, the quadratic coefficient (a) is not 1, which would result in a different answer than just using the residue theorem.
FreySmint
Hi! I'm new here, been a fan of this site for years, but only now I felt the need of registering.
Use the Residue Theorem to solve the integral:
∫[(cos(2t)) / (5-4*cos(t)) ] dt from t=0 to t=2pi2. The attempt at a solution
I did a variable change z=eit. With that:
(1/(2i))*∫[ (z2 + z-2) / (-2z2 +5z -2)]
Only taking the integral, I came up with:
∫[ (z4 +1) / (z2 * (z-1/2) * (z-2))]
Which has 3 singularaties: 1/2 , 2 and 0
Only 2 is not in the path considered.
The residue in 1/2 is -17/6 and in 0 is 5/2 as they are poles of order 1 and 2 respectively.
And with that, I have:
1/(2i) * 2*pi*i * (-17/6 + 5/2) = - Pi/3
Which is wrong, as the answer is actually Pi/6
Where did I go wrong?
Thanks in advance!
Thanks in advance!
Re-do the residue calculations
And notice that (z-1/2)*(z-2) is not equal to (-2z^2+5z-2).
ouch. Would have failed that test. Thanks for pointing that out Dick. Hope the op didn't spend a lot of time re-doing the residue calculations with the wrong factor.
Note that to get your original integral you have to integrate
[tex]f(z)=\frac{1}{\mathrm{i} z} \cdot \frac{z+z^{-2}}{2(5-2(z+1/z))}=\frac{\mathrm{i}(1+z^4)}{z^2(2z^2-5z+2)}[/tex]
along the unit circle [itex]z=\exp(\mathrm{i} t)[/itex] with [itex]t \in \{0,2 \pi\}[/itex].
Now you can use the residue theorem, which gives you immediately [itex]\pi/6[/itex]. To be honest, I've been lazy and did this with help of Mathematica :-).
Thanks everyone! I feel really stupid right now, my mistake was quite dumb... I had forgotten that when you use quadratic formula, if the quadratic coefficient (a) is not 1, you'll have a*(x-z1)(x-z2). I often forget the most basic stuff.
Thank you!
FAQ: Solving integral in complex analysis
What is an integral in complex analysis?
An integral in complex analysis is a mathematical tool used to calculate the area under a curve in the complex plane. It is similar to a regular integral in calculus, but it involves complex numbers and functions.
Why is it important to solve integrals in complex analysis?
Solving integrals in complex analysis allows us to understand and analyze the behavior of complex functions. It also helps in finding solutions to various problems in physics, engineering, and other fields.
What is the process for solving integrals in complex analysis?
The process for solving integrals in complex analysis involves using complex variable techniques such as the Cauchy-Riemann equations, contour integration, and the residue theorem. These techniques allow us to break down the integral into smaller, more manageable parts and solve them individually.
What are some common challenges in solving integrals in complex analysis?
Some common challenges in solving integrals in complex analysis include choosing the correct contour, dealing with singularities, and evaluating complex functions. It is important to have a solid understanding of complex analysis principles and techniques to overcome these challenges.
How can I improve my skills in solving integrals in complex analysis?
To improve your skills in solving integrals in complex analysis, it is important to practice regularly and familiarize yourself with different techniques and their applications. It may also be helpful to seek guidance from experienced mathematicians or attend workshops and seminars on complex analysis.
