Solving Trigonometric Equations
In summary, when solving trigonometric equations, one must be careful when using multiplication and division. It is important to avoid dividing by a term that can be equal to zero. This can be done by factoring and solving for both factors separately. Additionally, when squaring terms, it is important to check for extraneous roots. Further information on this topic can be found in calculus courses.
opticaltempest
135
I have a question when solving trigonometric equations.
For example:
Find all the solutions in the interval [0,2pi)
[tex]\sin \theta \tan \theta = \sin \theta \][/tex]
If you choose to divide through by [tex]\sin \theta\][/tex] we get,
[tex]\tan \theta = 1\][/tex] such that [tex]\sin \theta \ne 0\][/tex]
otherwise we are essentially dividing both sides by zero, which we
cannot do.
Do we need to be careful when solving trigonometric equations using
multiplication and division?
We're dividing by a term that can take on the value of zero. Does
this have any special name? How can I learn more about this?
Are there any techniques to use when solving trig equations
so this doesn't happen?
you can divide through even if it has the posibility of being = to zero.
the reason for this is because trig functions are FUNCTIONS. when you take calculus you'll see that you can examin how a function behaves close to zero.
as φ -> 0 for sinφ/sinφ , that ratio actually -> 1.
when it is = 0 try not deviding it out.
also, recall tanφ = sinφ/cosφ, so tan(0) = 0/1 = 0.
For example:
cannot do.
When you devide, you must make sure that the quantity that you use in the denominator is not zero. But in this case you can bypass division like this :
[tex]\sin \theta \tan \theta = \sin \theta[/tex]
[tex]\sin \theta \tan \theta - \sin \theta = 0[/tex]
[tex]\sin \theta ( \tan \theta -1) = 0[/tex]
Then you solve both
[tex]\sin \theta = 0[/tex]
and
[tex] \tan \theta -1 = 0[/tex]
regards
marlon
Squaring the terms is another thing which you have to be careful. You get extraneous roots out there.
FAQ: Solving Trigonometric Equations
What are trigonometric equations?
Trigonometric equations are mathematical expressions that involve trigonometric functions such as sine, cosine, and tangent. These equations can be solved for a specific variable in terms of the others, similar to other algebraic equations.
How do you solve trigonometric equations?
To solve a trigonometric equation, you must use algebraic manipulation and trigonometric identities to isolate the variable. This often involves using inverse trigonometric functions and finding the solutions within a given interval.
Why are trigonometric equations important?
Trigonometric equations are essential in various fields, such as engineering, physics, and astronomy. They are used to model and solve real-world problems involving angles, distances, and periodic phenomena.
What are some common strategies for solving trigonometric equations?
Some common strategies for solving trigonometric equations include using the Pythagorean identities, factoring, and substitution. It is also helpful to graph the equation and use the unit circle to visualize the solutions.
How do you check the solutions to a trigonometric equation?
To check the solutions to a trigonometric equation, you can substitute them back into the original equation and verify that both sides are equal. You can also use a calculator to graph the equation and see if the solutions line up with the points of intersection.
