Specific heat of different materials
In summary, the conversation is about calculating the specific heat of a "mixed" material using the specific heat data and weight percentages of each individual material. It is suggested that this method may not work if the materials react and form compounds. The conversation then shifts to estimating the specific heat of a material with given properties such as specific gravity, pH, and viscosity.
plucker_08
54
if I have 3 materials and mixed it, can I compute for the specific heat of the "mixed" material?
i have the data of the specific heat of each of the material and the precentage by weight.
example: material 1 is 46% of the total weight, material 2 is 52% and material 3 is 2%
cd = 0.46(4.186 ) + 0.52(3.4 ) + 0.02(4.3 ) = _____
thanks in advance!
Science news on Phys.org
Will the materials form compounds? If not, your approach should work fine.
they will form a dough
Ah. Well, the components are going to react, yes? So presumably the weighted method won't work for more than a few minutes/hours. After that, you'd need to use the specific heat of the new materials.
can you estimate the specific of a material having these properties?
specific gravity 1.09
PH 4.2
Viscosity 1,000 cP
That's funny. I don't know why, but it just is. Probably because it's so unusual: LOL.
what is so funny about that?
FAQ: Specific heat of different materials
What is specific heat?
Specific heat is the amount of heat required to raise the temperature of a substance by 1 degree Celsius or 1 Kelvin per unit mass.
Why is specific heat important?
Specific heat is important because it helps us understand how different materials respond to changes in temperature and how much energy is needed to produce those changes.
How is specific heat measured?
Specific heat is measured using a calorimeter, which is a device that measures the amount of heat absorbed or released by a substance during a change in temperature.
What are some factors that affect the specific heat of a material?
The specific heat of a material can be affected by factors such as the type of material, its phase (solid, liquid, gas), and its temperature.
How does specific heat relate to other thermodynamic properties?
Specific heat is related to other thermodynamic properties, such as enthalpy and entropy, through the first law of thermodynamics. It is also related to the heat capacity of a substance, which is the amount of heat required to raise the temperature of a substance by a certain amount.
