Arsonade
- 151
i do not know if the theory behind this will work, but seems plausable
now as far as i know, we have not attained the speed of light in any man made vehicle, however, 1/4 the speed of light seems a much more plausable situation. in this experiment, the set up looks somthing like this
http://i2.photobucket.com/albums/y13/Arsonade/theory.bmp
the back of each one of those capsules is a flat edge that has a miror face and a small camera on it (if 1/4th the speed of light is not unbearable for humans then it is a small capsule for veiwing instead) now each of hese are spinning on an axis the opposite direction of each other so that for a few brief miliseconds, the two back faces are facing each other, they are each spining at 1/4th the speed of light, am i wrong to asume that say, if you weere on the capsule, s you veiwed the other face/mirror moving away from you, first of all, you have a velocity of -1/4th the speed of light, you are veiwing the other going at a velocity of 1/4th the spead of light, so basically, you see the other face mving away from you at 1/2 the spead of light, now with the mirrors on these cpsules, the whole process is reversed, the light is refracted off the thing going 1/4th velocity witch then finds you at another -1/4th, this adds andother 1/2 the spead of light to it, the total should in theory be the spead of light, it should be at least observable.
i realize there are many many flaws in this experiment, namely that I am not sure that 1/4th spead of light has ever been attained, however, this is the spead of light , would actually veiwing the process be possible as veiwing needs light to work?
at least tell me if this idea is at all interesting.
Adam
Edit: apparently i can't get the graphic to load, no matter, it looks just like 2 centrifuges moving in opposite directions right next to each other, the explination in the post should explain it somewhat
Adam
