genxhis
- 37
- 1
I am not sure if I have done the following problem correctly.
To start, I do not know how to prove the electric field must be directed radially. Assuming this is true, then the magnitude of the field must be uniform along any spherical boundary (otherwise we could form a nonconservative loop that straddles this boundary). If we then apply Gauss's Law for dielectrics on a spherical surface of radius r, we have: 2 pi r2(K E + E) = Q/e0 or E = 1/(2 pi e0) Q/(1+K)r2. From this it easy follows Vab = 1/(2 pi e0) Q/(1+K) (1/a - 1/b) and then C = 2 pi e0 (1 + K) (a b)/(b - a). On reflection this does at least make some sense since the capacitance rises with stronger dielectrics and reduces to the standard expression when K = 1.
But the wording in part B implies the field strength is not the same in the lower and upper portions of the capacitor. And how one shows the field is directed radially throughout troubles me (though I can't imagine it being much else since it must at least be radial near the conductors).
An isolated spherical capacitor has charge +Q on its inner conductor (radius a) and charge -Q on its outer conductor (radius b). The lower half of the capacitor is filled with a liquid dielectric of constant K. a) Find the capacitance of the half-filled capacitor. b) Find the magnitude of E in the volume between the conductors as a function of the distance r from the center of the capacitor. Give answers for the both the upper and lower halves of this volume. c) Find the suface density of free charge on the upper and lower halves of the inner and outer conductors. d) Find the surface density of bound charge on the inner and outer surfaces of the dielectric. e) What is the surface density of bound charge on the flat surface of the dielectric? Explain.
