Stacking height of plastic bottles crates
In summary, the person is seeking help with justifying the stacking height of bottles crates in a public area. They mention potential hazards such as directional impact forces and wind load, and provide assumptions of using plastic crates with empty PET bottles and no typhoon. They are also looking for the number of levels that would ensure safety in this situation.
chi
Dear all,
I got a problem to justify the stacking height of bottles crates where locate at the public area.
As you may see the attached photo and draft as reference. The pattern of stacks like 4x10, 4x9, 4x8...(horizontal placement) or 2x10, 2x9, 2x8... (vertical placement).
In the public area, there are lots of directional impact forces and wind load which may make the bottles crates fallen down. If the external force applies to the crates, they will make someone getting hurt when walking on the street.
Assumption:
Plastic crates with empty PET bottles
Wind load (typhoon will not apply to this situation)
The thing is that how many levels should be a safety condition in public area. If you have any question, please feel free to contact me by email)
P.S. I got the additional draft and photo for reference (but files are over sizes putting on this post).
Chi (email: smallbee124@netvigator.com)
Please do not multiple-post!
Zz.
There's no picture. Also, it's not possible to solve this problem without further information (e.g, mass, volume, surface area, etc.). In any case, it is a quite difficult fluid mechanics question which I think would be best solved numerically.
FAQ: Stacking height of plastic bottles crates
How many plastic bottles can be stacked in one crate?
The exact number of plastic bottles that can be stacked in one crate depends on the size and shape of the bottles and the size of the crate. Generally, a standard crate can hold around 24 to 30 bottles, while larger crates can hold up to 50 bottles.
Can different types of plastic bottles be stacked together in one crate?
Yes, as long as the bottles are of similar size and shape, different types of plastic bottles can be stacked together in one crate. However, it is important to make sure that the bottles are not too heavy or too tall for the crate, as this can cause the stack to become unstable.
What is the maximum height that plastic bottles can be stacked in a crate?
The maximum height that plastic bottles can be stacked in a crate depends on the strength and stability of the crate itself. Generally, it is recommended to not stack the bottles higher than the top of the crate, as this can make the stack prone to tipping over.
How should plastic bottles be stacked to ensure stability?
To ensure stability, plastic bottles should be stacked in a pyramid or triangular shape. This means that the bottom layer should have a wider base than the top layer, with each subsequent layer getting smaller. This helps distribute the weight evenly and makes the stack less prone to toppling over.
Are there any safety precautions to keep in mind when stacking plastic bottles in crates?
Yes, there are a few safety precautions to keep in mind when stacking plastic bottles in crates. Make sure the crate is on a flat and stable surface, and do not stack the bottles higher than the top of the crate. Also, avoid stacking too many bottles in one crate, as this can make the stack top-heavy and unstable. Finally, always handle the stack with caution to prevent any accidents or injuries.
