Outrageous
- 374
Prove Ʃ1/(n^2) as n goes to infinity = (∏^2)/8
No idea how to start. Pls guide.
Thanks
Outrageous said:Homework Statement
Thanks
Thanks
Ray Vickson said:You need to show your work, first. Anyway, what is the context? Is this a problem in a course? If so, what is the course subject (analytic function theory, differential equations, Fourier analysis...)?
arildno said:You won't be able to prove it, since the result is wrong. The sum converges to [itex]\frac{\pi^{2}}{6}[/itex] instead
Thanks
Outrageous said:I got that from a manual solution, I don't know where should I ask my question so I put it here .
This answer is for quantum mechanics problem. I don't think that is Fourier series.
Outrageous said:Sorry for my mistakes. Thanks for replying.
Do I need to know f(x)= ? for solving this problem? Like f(x)=x for showing 1 - (1/3) + (1/5)...= ∏/4 .as shown below
Dick said:Use the same function, but instead of evaluating the series at a point, use Parseval's identity.
Outrageous said:f(x)= x .Range? -∏ <x< ∏ ?
What do you mean by evaluating the series at a point? Fourier series evaluating at a point
Complex fouries series and Parseval's theorem ?
Why do we need two types?
Dick said:Yes, exactly the same function, exactly the same series. Did you look up Parseval's theorem? Evaluating the series gives you things like 1/n, Parseval's gives you things like 1/n^2. Just try it.
Outrageous said:I got the answer by using parseval's theorem when f(x)=x over the interval -∏<x<∏.
Thanks
But when do I know I need to use complex Fourier series and parseval's theorem? Is that because there is a square? (2m+1)^2
[tex] \sum_{n=0}^{\infty} \frac{1}{(2n+1)^2} = \frac{\pi^2}{8}.[/tex]
Can I say Fourier series is used when my conjugate ,g(x) is not complex. Complex conjugate of g(x) = g(x), Eg. ∫g(x)f(x)dx= c
But when g(x) is complex , complex conjugate of g(x) is not equal to g(x),then I should use complex Fourier series?
This is my own conclusion after reading . Please Correct if it's wrong.
I am still don't understand what do you mean evaluate the series at a point, is that meant f(x)= x , the x should not be a point, so I have to integrate by using parseval's , but how do you know we can't treat it as a point?
Thanks
Dick said:Yes, the square is a hint you might need Parseval. But you didn't really finish the proof you presented in post 8. Could you do that? Then you might see why evaluation of the Fourier series at a point can give you the sum of some series.
The sum of 1/(n^2) as n goes to infinity is equal to π^2/6, also known as the Basel problem. This was first solved by Swiss mathematician Leonhard Euler in the 18th century.
This infinite series has important applications in mathematics and physics, particularly in the study of harmonic oscillators and the calculation of areas under curves.
The sum is calculated using the formula π^2/6, which can be derived using various methods such as the Euler-Maclaurin summation formula or Fourier series. It can also be approximated using numerical methods.
Yes, the concept of the Basel problem can be extended to other infinite series, such as the sum of 1/(n^s) as n goes to infinity for any real number s greater than 1. This is known as the Riemann zeta function.
Yes, this infinite series has been used in various fields such as number theory, quantum mechanics, and signal processing. It has also been used to calculate the probability of certain events in gambling and finance.
