Sum to the infinity of a series
In summary, the problem is trying to find the value of an infinite series with a logarithmic term, and the attempt at a solution involved using the arithmetico-geometric series and the expansion of ln(1+y). Hints suggest starting the sum from n=0 and simplifying the series by getting rid of (n-1) and using integration.
justwild
53
to find the value of [itex]\sum[/itex] over n=1 to ∞ of [1/{1+(n-1)2}](1/3)[itex]^{2+(n-1)2}[/itex]
I have tried to solve in the way the arithmetico-geometric series are solved and tried to bring it in the form of the expansion of ln(1+y), because the answer has logarithmic term in it.
Hints:
Get rid of the (n-1) by starting the sum off from n = 0, that'll make things clearer.
Observe that [itex]{(\frac{1}{3})}^{2 + 2n} =\frac{1}{3}.{(\frac{1}{3})}^{2n + 1}[/itex]
What's [itex]\int_0^x t^{2n} dt[/itex]?
FAQ: Sum to the infinity of a series
What is the "sum to infinity" of a series?
The "sum to infinity" of a series is the theoretical value obtained when all the terms of a series are added together without limit. It is also known as the "limit" of a series and is denoted by the symbol ∑.
How is the "sum to infinity" of a series calculated?
The "sum to infinity" of a series can be calculated using various mathematical techniques such as geometric series, telescoping series, and Taylor series. In some cases, the exact value may not be obtainable and only an approximation can be calculated.
What is the significance of "sum to infinity" in mathematics?
The concept of "sum to infinity" is important in mathematical analysis and helps in understanding the behavior of a series as the number of terms approaches infinity. It also has applications in various fields such as calculus, statistics, and physics.
Can the "sum to infinity" of a series be negative?
Yes, the "sum to infinity" of a series can be negative if the series contains alternating terms or if the terms approach negative values as the number of terms increases. However, the series is said to diverge if the absolute value of the "sum to infinity" is infinite.
What is the difference between a convergent and divergent series?
A convergent series is one whose "sum to infinity" approaches a finite value as the number of terms increases. On the other hand, a divergent series is one whose "sum to infinity" either approaches infinity or does not have a defined value. The convergence or divergence of a series depends on the behavior of its terms as the number of terms increases.
