Summation of continuous band of frequencies
In summary: He attempted to solve it using calculus, but is unsure of his skills and welcomes feedback.- The resultant signal can be described as the integral of sin(f*x) from f_low to f_high, with x as a constant.- The simplified equation for the entire signal is F(x) = cos(f_low*x)/x - cos(f_high*x)/x.- The frequency spectrum of the signal would be a rectangular function, or a sinc function in the time domain.- White noise is a term used to describe a signal with equal energy in all audible frequencies, similar to the sound produced by waves crashing or fans running at high speed.
cmorriss
Just got a "thought experiment" question from a colleague. The question, as phrased was: If an audio signal was composed by adding all of the frequencies in the audible range, what would it sound like?
I thought it was interesting, so I attempted to solve it by integral. My calculus skills have always been suspect, however, so I would appreciate some feedback.
If each component can be described as sin(f*x), where x is time and f specifies the frequency, then each moment of the resultant signal is the integral of sin(f*x) from f_low to f_high, treating x as a constant.
This should simplify to F(x) = cos(f_low*x)/x - cos(f_high*x)/x which describes the entire signal.
Anything wrong with that?
It's frequency spectrum would be a rectangular function. Hence in time domain it is the sinc function. If I got the question correctly
You don't need to use any math. If the signal contains equal energy in all of the audible frequencies, then it is called "white noise." You're probably already familiar with white noise, as it is produced (approximately) by everything from waves crashing against rocks, to fans running at high speed.
- Warren
FAQ: Summation of continuous band of frequencies
What is the summation of continuous band of frequencies?
The summation of continuous band of frequencies, also known as frequency summation, is the process of combining multiple individual frequencies to create a continuous band of frequencies. This can be achieved through the use of a filter or by adding together the individual waves.
What is the purpose of summation of continuous band of frequencies?
The purpose of summation of continuous band of frequencies is to create a more complex and varied signal, which can be used for a variety of applications such as signal processing, communication systems, and audio production.
How is summation of continuous band of frequencies different from summation of discrete frequencies?
Summation of continuous band of frequencies involves combining an infinite number of frequencies, while summation of discrete frequencies involves combining a finite number of frequencies. This means that the resulting signals will have different characteristics and applications.
What are some common methods for achieving summation of continuous band of frequencies?
Some common methods for achieving summation of continuous band of frequencies include the use of filters, Fourier analysis, and digital signal processing techniques. These methods allow for the manipulation and combination of individual frequencies to create a continuous band of frequencies.
What are some practical applications of summation of continuous band of frequencies?
Summation of continuous band of frequencies has many practical applications, including in wireless communication systems, audio engineering, and medical imaging. It is also used in scientific research to analyze and understand complex signals and phenomena.
