Summation of Series: Is the Radius from -∞ to ∞?
In summary, summing a series is the process of adding up all the terms in a sequence, and the result is the sum or total of the series. When summing a series from negative infinity to infinity, the radius refers to the range of values that the series can be summed over, and it is important to consider the radius as it determines the convergence or divergence of the series. The radius can be determined using convergence tests such as the ratio test, integral test, or comparison test. The radius of convergence can vary for different series and must be determined for each series individually.
MozAngeles
101
sum ((x-1)^(2n-2))/((2n-1)!) n=1..infinity?
after doing the ratio test, i found that the radius is from negative infinity to infinity (converges for all x).
is this right?
if not can you steer me in the right direction, please.
is this right?
Looks good to me.
thanks
FAQ: Summation of Series: Is the Radius from -∞ to ∞?
What is the meaning of "summing a series"?
Summing a series refers to the process of adding up all the terms in a sequence, starting from the first term to the last. The result of summing a series is called the sum or total of the series.
What is the "radius" when summing a series from negative infinity to infinity?
The "radius" in this context refers to the range of values that the series can be summed over. In this case, the radius is infinite, meaning that the series can be summed over an infinite range of values.
Why is it important to consider the radius when summing a series from negative infinity to infinity?
The radius is an important factor to consider because it determines the convergence or divergence of the series. If the radius is finite, the series will converge to a specific value. However, if the radius is infinite, the series may diverge and not have a specific sum.
How do you determine the radius when summing a series from negative infinity to infinity?
The radius can be determined by using the ratio test, which involves finding the limit of the absolute value of the ratio of consecutive terms in the series. If this limit is less than 1, the series will converge, and if it is greater than 1, the series will diverge. The radius can also be determined by using other convergence tests such as the integral test or the comparison test.
Can the radius of convergence change when summing a series from negative infinity to infinity?
Yes, the radius of convergence can change depending on the series being summed. Some series may converge over a finite radius, while others may converge over an infinite radius. It is important to determine the radius for each series individually to accurately determine its convergence.
