Superposition-airy disc-snell's law-qbits.
  • Thread starter Glen Bartusch
In summary: It was Louis deBroglie who proposed it, and it wasn't dismissed, it was shown to be wrong. Pilot wave theory is now called Bohmian mechanics, and it has been reformulated in a way which is mathematically equivalent to the Copenhagen interpretation.What happens, then, to the single photon as it exits its aperture? Assume the photon has a 600nm wavelength, and the aperture is 600nm round.The photon will diffract and create an airy pattern on the detector screen. The wave-like properties of light allow for interference and diffraction phenomena to occur, which can be described mathematically.
Glen Bartusch
57
The airy pattern is generated by a photon interfering with itself at the aperture. How is this possible? How can such a thing be visualized?
Also, since we can now predict with around 80% certainty the position of the qbit (superposed between a 1 and a 0), doesn't it stand to reason that we can also predict with equal certainty where the photon will land on the screen as it generates its airy pattern? After all, both particles are considered to be 'superposed' on themselves.
Discuss...
I think you're a bit off course here, but there is a thread, albeit a very old one, which seems to address this issue: https://www.physicsforums.com/showthread.php?t=11095
I think you're confusing the long-term statistical effects, with single particles, which do show up as a "dot" on the detector.
I went to the thread you posted, and it was the usual: some people proposing crackpottery; some people mastering the obvious and some people rehashing stuff from their 6th-grade science texts, with no one really answering the questions set fourth.
Every first-year phys. Student at caltech ggets to see the diffraction demonstration whereby a photon gets sent thru the slits one at a time, showing up as a 'dot on the detector'; eventually culminating in a usual diffraction pattern.
There is no difference between airy disc diffraction effects, single-slit diffraction effects, and multiple-slit diffraction effects-superposition of the photon upon itself (continued...)
(continued from above...)
is the phonomena that's supposed to be implicit in all diffraction effects. but how is superposition even possible? we can't describe a photon (or particle) as a 'wavepacket', since wavepackets can't really exist in nature (neither can strings, branes or other forms of physics crackpottery).
Nor can we say that a 'photon is a wave until we look at it', since Dirac's pilot wave hypothesis was routinely dismissed shortly after it was proposed.
Hello,
The airy disc is a diffraction phenomenon, and well-described by classical wave mechanics. So this best thought of as a 'wave-like' property of light, rather than a 'particle-like' property. Speaking of a photon (a 'particle' picture) 'interfering with itself', is of course non-intuitive.
Where did 80% certainty and qbits come from here?
A "qbit" is something which has discrete states (e.g. spin up/down of an electron), just like a digital bit. Unlike a digital bit it can be in a superposition of both states at once. But the position of a photon isn't a qbit, because position is not a discrete state.
If you are dealing with single photon, you can predict the probabilities of where it will it will be detected.
Both particles?
The same way it is for classical waves, and anything else that obeys a linear differential equation.
That's just silly. All mathematical concepts are abstract things which "don't exist in nature", yet this doesn't mean you can't describe things mathematically. Whether or not you take the philosophical position, for instance that the wave function is a 'real thing', has no bearing at all whether or not it works as a physical description.
It wasn't Dirac's theory.
FAQ: Superposition-airy disc-snell's law-qbits.
What is superposition in physics?
Superposition is a principle in quantum mechanics that states that a physical system can exist in multiple states or configurations simultaneously. This means that a particle can be in multiple places or have multiple properties at the same time.
What is an Airy disc?
An Airy disc is a diffraction pattern that appears when a point source of light is observed through a circular aperture. It is characterized by a central bright spot surrounded by concentric rings of decreasing intensity. This phenomenon is caused by the wave nature of light.
What is Snell's Law?
Snell's Law, also known as the law of refraction, describes the relationship between the angle of incidence and the angle of refraction when a light ray passes through a boundary between two materials with different refractive indices. It states that the ratio of the sine of the angle of incidence to the sine of the angle of refraction is equal to the ratio of the two materials' refractive indices.
What are qubits?
Qubits are the basic units of quantum information in a quantum computer. They are quantum bits that can exist in multiple states at the same time, allowing for much more complex and faster processing than classical bits. They are represented by the quantum states of a physical system, such as the spin of an electron or the polarization of a photon.
How are superposition, Airy disc, Snell's Law, and qubits related?
Superposition is a fundamental principle in quantum mechanics, which is the basis for understanding qubits and their ability to exist in multiple states at the same time. Snell's Law is a classical example of light exhibiting wave-like behavior, which is also a key principle in understanding quantum phenomena such as the Airy disc. These concepts are all interconnected and fundamental to understanding the behavior of matter and energy at the quantum level.
