smithg86
- 59
[SOLVED] the addition of three simple harmonic motion
A particle is simultaneously subjected to three simple harmonic motions, all of the same frequency and in the x direction. If the amplitudes are 0.25, 0.20 and 0.15 mm, respectively, and the phase difference between the first and second is 45 degrees, and between the second and third is 30 degrees, find the amplitude of the resultant displacement and its phase relative to the first (0.25 mm amplitude) component.
(the sum from i=1 to n) tan x = (the sum from i=1 to n) sin x / (the sum from i=1 to n) cos x
Ae^(jrt) = A[cos(rt) + j sin(rt)], where j^2 = -1
I was able to do the first part and confirm the answer in the back of the book:
amplitude of resultant displacement ~= 0.52 mm.
for part 2, let:
first angle = x_1
second angle = x_2
third angle = x_3
i know:
|x_1 - x_2| = 45 degrees
|x_2 - x_3| = 30 degrees
thus:
x_1 = 75 degrees + x_3
x_2 = 30 degrees + x_3
I was unsure how to find the resulting phase without more information about the angles. I tried to use the above tan x formula but could not get rid of the x_3 terms...
for part 2, let:
first angle = x_1
second angle = x_2
third angle = x_3
i know:
thus:
