The divergence of 1/r^2 fields
In summary, the divergence of the function v=1/r2r (bold is for vector and italic for versor) is zero, which means there is no net flux across the surface of the differential volume. This divergence is important because it describes the density of sources of a field.
Aikon
Hi people,
It is my first post here :)
It is not a homework problem because i solved it (and at least i think i am right...).
The question is as follows: In problem 1.16 (Intro. to eletrodynamics, Grifitths, 3rd edition) he asks to calculate the divergence of the function v=1/r2r (bold is for vector and italic for versor).
That divergent results zero! And i want to know what this zero means mathematicaly, physicaly, ...?
zero distance between the particles?
The resulting field is infinite, which isn't really physically meaningful, and certainly not observed, but in approximations to zero you can say it's really big.
The trick is to calculate it by "brute force" and then using the divergence theorem, putting those two together gives you the definition of the so called Dirac delta function, which is what the divergence really is.
Mathematically it means that the net flux across the surface of a differential volume is zero.
Physically it depends on what v is. If for example v is the E-field then it means there is no source of the E-field (charge) within the differential volume.
Oh, the divergence of 1/r^2r. Whoops.
The form
[tex] \vec A = A\frac {\hat r}{r^2} [/tex]
is an inverse square field. It is proven the divergence of an inverse square field is always equal zero.
If vector A is an inverse square field, it is a conservative field. and
[tex] \vec A = \nabla \Phi \hbox { where } \Phi \hbox { is some scalar function.}[/tex]
Work done on a particle by A is path independent and equal to zero if it is a closed path...yada yada.
Google " conservative field " to get more detail.
Electro static field E is a conservative field.
Watch out, divergence of a vector equal zero do not imply the vector is a conservative field. It only say the divergence of a conservative field is zero.
yungman said:
The form
Except at r=0 of course
Forgot, conservative is not defined at r=0...I guess that falls into the yada yada part!:smile:
See, the yada yada is a very good way to CYA!
yungman said:
The form
This is somewhat correct:
1) the divergence of
is zero NEARLY everywhere and the 'nearly' is very important because the integral of this divergence over a volume including the origin is not zero. Using distribution theory you would write
[tex] div( A\frac {\hat r}{r^2})=4A\pi\delta(\vec r) [/tex]
The divergence basically describe the density of sources of a field. The basic example of this field is the electrostatic field generated by a point-like charge
2) the divergence of a conservative field is far from being always zero. A field with zero divergence is usually called solenoidal, a field with zero curl is called conservative. Any general field can be decomposed in the sum of a soleinodal and a conservative field (Helmoltz theorem).
There should be a whole section in a lot of calculus books, not going to list all the characteristics here. I suggested OP to search for the info on web. All the remain belong to the yada yada.
Yes the origin is not defined, but if you expand the divergence of the given conservative field, it is equal to zero for all points that the field is defined...that is excluding origin or |r|=0. Isn't it?
Congratulations! You have taught me a new word. :smile:
In 25 years of teaching physics and 15 years of studying it before that, I don't think I have ever before seen the word "versor." But a Google search took me to a Wikipedia page which indicates that "versor" is indeed sometimes used to refer to what is usually called a "unit vector" in English. Maybe in some other languages this word (or rather its equivalent) is used more.
It's a nice word, and I wish I could use it in my classes, but I'm afraid that it would confuse many of my students because none of our textbooks use it. :cry:
FAQ: The divergence of 1/r^2 fields
What is the divergence of 1/r^2 fields?
The divergence of 1/r^2 fields refers to the behavior of a vector field with a magnitude that decreases as the inverse square of the distance from its source. This type of field can be found in many physical phenomena, such as gravitational and electrostatic fields.
How is the divergence of 1/r^2 fields calculated?
The divergence of 1/r^2 fields is calculated using the divergence theorem, which states that the flux of a vector field through a closed surface is equal to the volume integral of the divergence of the field within the surface. In simpler terms, it is a measure of how much the field is spreading out or converging at a given point.
What is the significance of the divergence of 1/r^2 fields?
The divergence of 1/r^2 fields plays an important role in understanding the behavior of physical systems, as it can provide insights into the flow of energy and matter. It also has implications in areas such as fluid dynamics, electromagnetism, and gravitational fields.
Can the divergence of 1/r^2 fields be negative?
Yes, the divergence of 1/r^2 fields can be negative. This means that the field is converging at a particular point, indicating that there is a source of the field at that point. In contrast, a positive divergence indicates that the field is spreading out.
Are there any real-world examples of 1/r^2 fields?
Yes, there are many real-world examples of 1/r^2 fields. Some common ones include the gravitational field around a point mass, the electric field around a point charge, and the magnetic field around a straight current-carrying wire. These fields follow an inverse square law, where the strength decreases with the square of the distance from the source.
