The Existence Uniqueness Theorem
In summary: The purpose of the Existence Uniqueness Theorem is to show that a certain kind of equation is satisfied by a unique solution.
bmed90
99
In your own words, what exactly is the purpose of the Existence Uniqueness Theorem and why is it useful
1, Theorems have no purpose. They are either true or false.
2. Theorems in general have little usefulness for the purpose of peeling a banana, for example.
Don't you think it is nice to know whether or not a problem has a solution before you begin trying to solve it? As for uniqueness, think about the applications of differential equations to phsics. If you were to drop something repeatedly, isn't it nice to know that the uniqueness of solutions to the differential equation guarantee that it will always fall in the same way? Physics would be very complicated if experiments done repeatedly, in exactly the same way, could have many different outcomes.
Here's an example of an experiment that can: Balance a very thin rod on one end. With absolutely no "perturbation", that rod would stay balanced but, of course, there are always some kind of air current or other perturbation. And there is no way of telling in which direction the rod will fall precisely because the differential equations governing the situation do NOT satisfy the hypotheses of the "uniqueness theorem"
Here is an interesting application of the "uniqueness" property:
Suppose a taut wire is attatched to a point on the wall (the wire cannot move up or down at that point) and a single "hump" is formed on the wire, above the line of the wire when untouched, which then moves toward the wall satifying the "wave" equation. Of course, the hump is "reflected" when it hits the wall. Does it come back above or below the wall?
The wave equation is a nice, well behaved, that certainly satifies the conditions of the "existence and uniqueness" theorem for diferential equations. If we imagine the wire extending beyond the wall, so there is no wall and no fixed point there, and second hump, beyond the wall, symmetric to the first except that it is upside down, when the two humps hit the wall, they will cancel, not moving the point at the wall.
That is, that "double hump wave" satisfies the wave equation and the boundary condition that the point on the wall not move. As the original wave continues past the wall, the upside down wave continues on this side. Since the solution is unique, and that "double wave" satisfies both the equation and the boundary condition, it must be the same as the solution to the original problem. That is, the wave must reflect upside down.
You can use the same argument, looking at the slope of the wave, to show that if the point on the wall is allowed to move up and down (on a rail, perhaps) but the wire is force to have slope 0 there, the wave is reflected still above the horizontal.
Related to The Existence Uniqueness Theorem
1. What is the Existence Uniqueness Theorem?
The Existence Uniqueness Theorem is a mathematical theorem that guarantees the existence and uniqueness of solutions to certain mathematical equations or problems. It is often used in the field of differential equations, but can also be applied to other areas of mathematics.
2. How does the Existence Uniqueness Theorem work?
The theorem states that if a certain set of conditions are met, then there will be one and only one solution to the given equation or problem. This means that there cannot be multiple solutions or no solutions at all. The theorem provides a way to prove the existence and uniqueness of solutions in a rigorous and systematic manner.
3. What are the conditions required for the Existence Uniqueness Theorem to be applied?
The conditions for the theorem to be applied vary depending on the specific equation or problem being solved. However, some common conditions include the continuity and differentiability of the equation or problem, as well as certain boundary conditions or initial values. These conditions ensure that the solution is well-defined and unique.
4. Why is the Existence Uniqueness Theorem important?
The Existence Uniqueness Theorem is important because it provides a powerful tool for proving the existence and uniqueness of solutions to mathematical problems. This is crucial in many fields of science and engineering, where accurate and reliable solutions are required. The theorem also allows for the development of numerical methods to approximate solutions to complex problems.
5. Are there any limitations to the Existence Uniqueness Theorem?
Yes, there are limitations to the theorem. It may not be applicable to all types of mathematical problems, and the conditions required for its application can be quite restrictive. Additionally, the theorem does not provide an explicit method for finding the solution, but rather proves its existence and uniqueness. Therefore, it is important to carefully consider the conditions and assumptions when using the theorem to ensure its applicability.
