The limit of a function as x--> infinity
In summary, the conversation discusses the concept of limits in mathematics and how to determine the limit as x approaches infinity. It is noted that strictly speaking, the limit is undefined in this case because there is no specific number that the function converges to. However, it is commonly accepted to say that the limit is infinity in these scenarios as a shorthand for the function increasing beyond all boundaries. The possibility of the limit being negative infinity is also mentioned, as well as the case where the numbers do not converge at all.
Matejxx1
72
Hi everyone,
So we were writting our math test today and I am not completely sure about one concept.
For the sake of simplicity let's say that
f(x)=x2
and let's say we were asked to find,
lim f(x) as x--->infinity = ?
is the correct answer here undefined or infinity.
Thanks for the help
Mathematics news on Phys.org
Both to some extend. Strictly speaking the limit is undefined because there is no number ##f(x)## converges to. And ##∞## cannot be used within the formal definition of a limit. However, in contrast to a situation like, e.g. ##\lim_{n→∞}{(-1)^n}## we may say that the limit increases beyond all boundaries which is basically the formal definition in case ##f(x)## goes to infinity. Therefore we may note ##\lim_{x→∞}{f(x)} = ∞## for short which indicates the need to apply the "beyond all boundaries" version of the definition and allows us to distinguish such a behaviour from divergent cases as in my example.
Likes Matejxx1
Saying that "the limit is infinity" is just shorthand for "the limit does not exist- for a specific reason". That specific reason is that the number get larger and larger without bound. It is also possible that the numbers get lower and lower (are negative number with absolute value getting larger and larger without bound). In that case the limit also does not exist but we might say "the limit is negative infinity". Neither of those is ambiguous because "infinity" and "negative infinity" are not real numbers. There is, of course, a third possibility- that the numbers do not get "larger and larger without bound" nor "lower and lower without bound" but still do not converge. For example [itex](-1)^n[/itex] or [itex](-1)^nn[/itex]
Likes Matejxx1
FAQ: The limit of a function as x--> infinity
What is the definition of the limit of a function as x--> infinity?
The limit of a function as x approaches infinity is the value that the function approaches as the input variable (x) becomes infinitely large.
How do you calculate the limit of a function as x--> infinity?
To calculate the limit of a function as x approaches infinity, you can use the following steps:
1. Substitute infinity for x in the function.
2. Simplify the resulting expression, if possible.
3. If the expression does not have a finite value, the limit does not exist.
4. If the expression has a finite value, that is the limit of the function as x approaches infinity.
What does it mean if the limit of a function as x--> infinity does not exist?
If the limit of a function as x approaches infinity does not exist, it means that the function does not have a single, finite value that it approaches as the input variable becomes infinitely large. This can occur when the function oscillates or has asymptotes at infinity.
Is it possible for a function to have a limit as x--> infinity but not as x--> -infinity?
Yes, it is possible for a function to have a limit as x approaches positive infinity, but not as x approaches negative infinity. This occurs when the function has a different behavior at positive and negative infinity, such as having different asymptotes or approaching different values.
Can the limit of a function as x--> infinity be infinity?
Yes, the limit of a function as x approaches infinity can be infinity, but only if the function's value increases without bound as x becomes infinitely large. This can occur with exponential or polynomial functions with positive exponents.
