shotgun
- 30
How far into space do we need to look before we can see the first signs of redshift?
shotgun said:so you are saying that gravity does not involve the acceleration of one rest mass towards another with the consequence that the distance between the two is reduced?
shotgun said:And then isn't the changing rate at which this distance is being reduced the same thing as saying that they are accelerating towards each other?
Redshift is the shift of light towards longer wavelengths, which is caused by the expansion of the universe. It is measured by comparing the observed wavelength of light from an object to the expected wavelength of that light based on its known properties.
Redshift is important in astronomy because it provides evidence for the expansion of the universe and helps us understand the distance and age of objects in the universe. It also allows us to study the evolution of galaxies and the large-scale structure of the universe.
The Big Bang theory predicts that the universe is expanding, and redshift is a direct consequence of this expansion. As the universe expands, the light from distant objects is stretched, causing their wavelengths to shift towards the red end of the spectrum.
Yes, redshift can be used to estimate the age of the universe. By measuring the redshift of distant objects and using the known rate of expansion of the universe, we can calculate the age of the universe to be approximately 13.8 billion years.
Yes, there are two types of redshift: cosmological redshift and Doppler redshift. Cosmological redshift is caused by the expansion of the universe, while Doppler redshift is caused by the relative motion between an object and an observer. Both types are important in measuring distances and understanding the structure of the universe.
