D_Tr
- 45
- 4
Container 1 has a volume of 10 ft^3 and contains ideal gas at a pressure of a atm and temperature of 273 F.
Container 2 has a bolume of 1 ft^3 and contains the same quantity of ideal gas at a pressure of 0.1 atm and temperature of 273 F.
The two containers are separated by a stopcock. We then open the stopcock until pressure equilibrium is achieved. Find the final temperature of each container as well as the quantity of gas transferred between the two containers.
The state equation for ideal gases: P*V = n*R*T
The first law of thermodynamics for open systems (?)
I have a solution for the problem from the professor but I cannot make full sense of it. I can post the full solution if you think I sould. Basically, at the start, the equilibrium pressure is calculated using the law of partial pressures: Pf = (P1initial*V1 + P2initial*V2)/(V1+V2) = 2/11 atm.
At the end the temperatures calculated for each container are different. My question is why do we have different temperatures. Even if we close the stopcock as soon as pressures become equal witout caring about temperature, why should temperatures at the end be different? (352 F for container 2, -89 F for container 1). For this to happen the molecules in container 1 (high pressure) must lower their average kinetic energy right? When we open the stopcock molecules are only bouncing in the container walls and with other molecules of the same temperature. The solution seems to assume that the gas in the high pressure container acts as a piston that does work on the gas in the low pressure container, thus transfering energy to the low pressure gas and heating it. It uses the first law of thermodynamics for an open system (system is defined as the volume of the high pressure container) and arrives at: (T1f/T1i) = (Pf/P1i)^((γ-1)/γ). However, for the "piston made of gas molecules" assumption to hold we must assume that the molecules of the ideal gas have some volume otherwise each container's molecules would expand into the other container as if other molecules were not there. Have I correctly interpreted the solution to the problem? Sorry for the lengthy post and thanks for your time .
