Thermo Question - Fridge cycles
In summary, we are considering a 300 kJ/min refrigeration system using an ideal vapor-compression cycle with refrigerant-134a. The refrigerant enters the compressor as saturated vapor at 140 kPa and is compressed to 800 kPa. The quality of the refrigerant at the end of the throttling process is determined using the ideal gas law, and the coefficient of performance is found to be 0.6. The power input into the compressor is 5 kW.
Jacob87411
171
Consider a 300 kJ/min refrigeration system that operates on an ideal vapor-compression cycle with refrigerant-134a as the working fluid. The refrigerant enters the compressor as saturated vapor at 140 kPa and is compressed to 800 kPa. Determine the (a) quality of the refrigerant at the end of the throttling process, (b) the coefficient of performance, and (c) the power input into the compressor.
In a refigeration cycle I am considering state 1 after the evaporator, 2 after the compressor, 3 after the condenser and 4 before the evaporator.
P1=140 kPa, x (quality)=1 since its a saturated vapor.
P2=800 kPa, x=1
W=m(h2-h1)
300 kJ/min = 5KW
In an ideal refigeration cycle isn't the only work considered the work for the compressor, so isn't the answer to (c) 5KW?
I'm having the most problems with (a) because I am unsure to begin. I can find other states such as enthalpies with the pressure I have been given, is that the correct approach?
(a) The quality of the refrigerant at the end of the throttling process can be determined using the ideal gas law. Since the pressure is known (P2 = 800 kPa), the specific volume can be calculated using the ideal gas law:v2 = R * T2/P2, where R is the gas constant for refrigerant-134a, and T2 is the temperature at state 2. The quality is then given by x = (v_g - v_f)/(v_g - v_f), where v_g and v_f are the specific volumes of the saturated vapor and saturated liquid, respectively. (b) The coefficient of performance is defined as the ratio of the net work output to the input energy required by the compressor. In this case, the net work output is 300 kJ/min, while the input energy required by the compressor is 5 kW. Therefore, the COP is 60 kJ/kW = 0.6.(c) The power input into the compressor is 5 kW.
Yes, the work input into the compressor is 5 kW, as it is the only part of the cycle that requires work. To determine the quality of the refrigerant at the end of the throttling process (state 4), we can use the fact that the throttling process is isenthalpic (meaning there is no change in enthalpy). This means that the enthalpy at state 4 will be equal to the enthalpy at state 3 (after the condenser). Using the pressure and enthalpy values at state 3, we can determine the enthalpy at state 4. From there, we can use the saturated vapor table for refrigerant-134a to find the corresponding temperature and quality at state 4.
The coefficient of performance (COP) for a refrigeration cycle is defined as the ratio of the desired output (cooling effect) to the required input (work input). In this case, the COP can be calculated as the ratio of the cooling effect (300 kJ/min) to the work input (5 kW), giving a COP of 60.
To summarize:
(a) To find the quality at state 4, use the isenthalpic condition and the saturated vapor table for refrigerant-134a.
(b) The COP can be calculated as the ratio of the cooling effect to the work input.
(c) The power input into the compressor is the only work input in an ideal refrigeration cycle, so it is equal to 5 kW.
Related to Thermo Question - Fridge cycles
What is a fridge cycle?
A fridge cycle refers to the process of cooling and maintaining a constant temperature inside a refrigerator. This process involves the compressor, condenser, evaporator, and expansion valve working together to transfer heat from inside the fridge to the outside environment.
How often should a fridge cycle occur?
The frequency of fridge cycles can vary depending on factors such as the age and model of the refrigerator, the ambient temperature, and the amount of food stored inside. On average, a fridge cycle can occur every 30 minutes to 2 hours.
What is the ideal temperature for a fridge?
The ideal temperature for a fridge is between 35-38°F (1.7-3.3°C). This temperature range is considered safe for storing food and preventing bacterial growth. It is important to check and adjust the temperature periodically to ensure food safety.
Why does a fridge cycle on and off?
A fridge cycles on and off to maintain a consistent temperature inside. When the temperature inside the fridge rises, the compressor turns on to cool the air. Once the desired temperature is reached, the compressor turns off until the temperature rises again. This cycle continues to keep the temperature stable.
How can I tell if my fridge cycles too often?
If you notice that your fridge is constantly running and cycling on and off, it may be a sign of a problem. This could be caused by a faulty thermostat, dirty condenser coils, or a malfunctioning compressor. It is best to have a professional inspect and repair the fridge to prevent further damage.
