Time dependent Hamiltonians: features
In summary, the definition of energy for quantum systems with time dependent Hamiltonians is not straightforward. While the eigenvalue of the Hamiltonian is time-dependent, the eigenstates are stationary states and do not change with time. This inconsistency raises the question of the general definition of energy when non-conservative forces are present in classical mechanics. In quantum mechanics, the energy is not conserved and cannot be used to label states when the Hamiltonian is time-dependent. The best approach is to use the formula given by juanrga, which applies to both pure and mixed states.
abhinavd
What is the definition of energy for quantum systems with time dependent Hamiltonians? Is it the eigenvalue of the Hamiltonian? (The eigenvalue is, in general, time dependent). However, the eigenstates of the Hamiltonian (even if it is time dependent) are stationary states, and hence no quantities must change with time. What is the reason for this inconsistency?
This leads us to this general question in classical mechanics: What is the general definition of energy when non-conservative forces are present? We'd defined energy as a quantity that remains unchanged with the time translational invariance of the Lagrangian, but that does not hold when time dependent potentials are present.
[itex]\left\langle E \right\rangle \equiv Tr \{ \hat{H} \hat{\rho} \}[/itex]
You did not address the question of whether the energy is a function of time, and how it reconciles with the fact that it is a stationary state. So before going on to mixed states, let's answer the question for pure states, the eigenstates of the time dependent Hamiltonian.
The expression for the energy is valid when H=H(t), and deals with both pure and mixed states. The equation for dE/dt is derived from it in the usual way (just derive both sides of the equation)
When the Hamiltonian is time-dependent, time translational invariance is absent. Since the symmetry is absent, the corresponding Noether charge is not a conserved quantity. Put differently: energy is not conserved in systems with a time-dependent Hamiltonian. This applies to both classical and quantum mechanical systems.
For classical systems we can still define the energy, and this quantity will violate conservation laws (i.e. be time-dependent). For quantum mechanical systems the energy is no longer a proper quantum number and cannot be used to label states. The best thing we can do is to use the formula given by juanrga -- it applies to both pure and mixed states.
FAQ: Time dependent Hamiltonians: features
What is a time dependent Hamiltonian?
A time dependent Hamiltonian is a mathematical operator used in quantum mechanics to describe the evolution of a physical system over time. It takes into account the kinetic and potential energies of the system, as well as any external forces acting on it.
2. How is a time dependent Hamiltonian different from a time independent Hamiltonian?
A time dependent Hamiltonian varies with time, meaning its values change as the system evolves. This is in contrast to a time independent Hamiltonian, which remains constant throughout the system's evolution.
3. What are some examples of systems that can be described by time dependent Hamiltonians?
Some examples include quantum mechanical systems such as atoms, molecules, and nuclei, as well as classical systems such as fluids and plasmas. Time dependent Hamiltonians can also be used to describe the behavior of particles in electromagnetic fields.
4. What are the features of time dependent Hamiltonians?
Time dependent Hamiltonians have several key features, including non-commutativity (meaning the order of operations matters), time-dependence, and the ability to account for external forces and interactions.
5. How are time dependent Hamiltonians used in research and practical applications?
Time dependent Hamiltonians are used in a wide range of research fields, including quantum chemistry, condensed matter physics, and nuclear physics. They are also used in practical applications, such as in the design of electronic devices and in the development of new materials.
