Time independent perturbation theory
In summary, the equation H=H0 + lambda * W states that for accurate results, lambda should be significantly smaller than 1 and the matrix elements of W should be comparable in magnitude to those of H0. Specifically, the matrix elements of W should be of the same magnitude as the difference between the eigenvalues of H0. This means that the values in the matrix W should be roughly equal to the difference between two eigenvalues of H0.
cks
165
H=H0 + lambda * W
lambda << 1 must hold and the matrix elements of W are comparable in magnitude to those of H0.
More precisely, the matrix elements of W are of the same magnitude as the difference between the eigenvalues of H0.
I don't understand what is the meaning of " the matrix elements of W are of the same magnitude as the difference between the eigenvalues of H0".
(the above explanation are obtained from the SChaum's Outlines of Quantum Mechanics)
Let's say the matrix W=[2.2 3.1 4.1; 4.1 5.3 6.0; 7.3 8.2 9.3] (matlab code)
let's say the eigenvalues of H0 are 1 2 3 4 5 6 7 8 9
the matrix element 2.2 is roughly the same as the difference of the eigenvalues of 3-1. Am I understanding this correctly?
the matrix elements of W are of the "same magnitude"(don't understand what same magnitude means?) as the difference(difference? difference between which eigenvalues, in my example, there are 9 eigenvalues, which minus which is the difference the author is talking?) between the eigenvalues of H0".
Time independent perturbation theory is a powerful tool used in quantum mechanics to approximate the behavior of a system when a small perturbation is introduced. In this case, the perturbation is represented by the term lambda * W, where lambda is a small parameter and W is a perturbation operator.
The condition lambda << 1 ensures that the perturbation is small enough to be treated as a perturbation rather than a significant change to the system. This allows us to use perturbation theory to calculate the corrections to the energy levels and wavefunctions of the system.
The statement that "the matrix elements of W are of the same magnitude as the difference between the eigenvalues of H0" means that the perturbation operator W is comparable in size to the difference between the energy levels of the unperturbed system, H0. This condition is important because it ensures that the perturbation is strong enough to cause significant changes in the system, but not too strong that it completely dominates the behavior of the system.
In summary, time independent perturbation theory is a useful tool in quantum mechanics when dealing with small perturbations to a system. The conditions of lambda << 1 and comparable matrix elements of W to the energy differences of H0 are crucial in ensuring the accuracy and applicability of this theory.
FAQ: Time independent perturbation theory
What is time independent perturbation theory?
Time independent perturbation theory is a mathematical method used in quantum mechanics to approximate the energy levels and wave functions of a system that has been slightly perturbed from its original state. This perturbation can be caused by external factors such as an electric or magnetic field.
How does time independent perturbation theory work?
The basic principle of time independent perturbation theory is to treat the perturbation as a small disturbance on top of the original system. This allows us to use a series expansion, called the perturbation series, to calculate the new energy levels and wave functions. The first term in the series gives a good approximation, and each subsequent term improves the accuracy of the result.
What are the assumptions of time independent perturbation theory?
There are three main assumptions of time independent perturbation theory: 1) the perturbation is small, 2) the original system is known, and 3) the perturbation is time independent. These assumptions allow us to use the perturbation series and make the necessary approximations to calculate the perturbed energy levels and wave functions.
When is time independent perturbation theory applicable?
Time independent perturbation theory is applicable when the perturbation is small compared to the original system. It is also useful when the original system is known, such as in simple quantum mechanical systems, and when the perturbation is time independent, meaning it does not change with time.
What are the limitations of time independent perturbation theory?
Time independent perturbation theory is limited to small perturbations, and the accuracy of the results decreases as the perturbation becomes larger. It also assumes that the original system is known, which may not always be the case. Additionally, it does not take into account any changes in the system over time, as it only considers the perturbation at a single moment in time.
