Torque and volumetric efficiency relationship
In summary, the OP asked about the torque curve of an engine and whether it peaks at a certain rpm range. The answer is that the torque is maximum at a certain rpm range, but it's not dependent on the volumetric efficiency.
rambharath94
Hello Guys,
From the torque curves of most of the ic engines it can be seen that torque is maximum at a particular rpm range then it starts dropping. It is said that the torque is maximum when the volumetric efficiency is maximum , i just can't understand the relationship between the both these quantities.
Better volumetric effficiency means more air; more air means more fuel can be burned; more fuel burned means bigger explosion; bigger explosion means more torque.
Volumetric efficiency depends on intake & exhaust design and valve overture. Unless there is a variable design (variable valve timing for example), the system is usually tuned for a certain rpm range, hence the peak torque at a certain rpm.
As rpm increases, the intake and/or exhaust system can choked, not being able to fill completely the cylinder, hence a drop in volumetric efficiency.
That is not exactly true. volumetric efficency is the ratio of engergy consumed vs energy generated. i believe this to be at max torque, but it doesn't mean its at the point where the most amount of air and fuel is burned. that will happen at max HP. Hp-seconds is the unit measure of work. the most energy will be used at max hp because that is the engines greatest capacity for work, so most amount of fuel will be used at ths point in the curve. Max torque of the engine is only about the angles and sizes of pistons and cranks... the torque you are really concerned about, is that at the rear wheels, through the gear box. The greatest acceleration forces will happen at max HP, NOT a max torque for any given vehicle speed.
Zanick write equation down for volumetric efficiency.
Check your work with the oracles of google if you like.
By the way, you've totally missed the point of the OP's question, and have subsequently made a total mess of trying to contradict jacks answer.
Likes jack action
FAQ: Torque and volumetric efficiency relationship
What is torque and volumetric efficiency relationship?
Torque and volumetric efficiency relationship is the relationship between the torque produced by an engine and its volumetric efficiency, which is the measure of how effectively an engine can move air in and out of its cylinders.
How are torque and volumetric efficiency related?
Torque and volumetric efficiency are directly related, meaning that as one increases, the other also increases. This is because an engine with high volumetric efficiency can draw in more air and fuel, resulting in a greater combustion force and therefore higher torque output.
Why is the relationship between torque and volumetric efficiency important?
The relationship between torque and volumetric efficiency is important because it determines the overall performance and power output of an engine. A higher torque output means the engine can produce more power, while a higher volumetric efficiency means the engine is more efficient at using the air and fuel to generate that power.
How can the relationship between torque and volumetric efficiency be improved?
The relationship between torque and volumetric efficiency can be improved by increasing the engine's volumetric efficiency through modifications such as adding a turbocharger or supercharger, optimizing the intake and exhaust systems, and adjusting the timing and fuel injection processes.
Are there any limitations to the relationship between torque and volumetric efficiency?
Yes, there are limitations to the relationship between torque and volumetric efficiency. As an engine reaches its maximum volumetric efficiency, the relationship between torque and volumetric efficiency may become less significant. Additionally, external factors such as air temperature and altitude can also affect the relationship between torque and volumetric efficiency.
