Transfer of electricity wihout loss safely.
In summary, using fast moving hydrogen ions in a long glass tube with a vacuum for electricity transfer is not a feasible option. The hydrogen ions would need to be continuously produced by consuming energy and when they reach the destination, they form hydrogen gas and generate electricity. However, the efficiency for long ranges is questionable and there are additional losses involved. It would also be difficult to produce and guide a high current beam of protons or electrons without dispersion or hitting the sides of the tube. Metal wires are a more efficient and practical option for electricity transfer.
shivakumar06
69
can we use fast moving hydrogen ions in long glass tube which are practically vacuum for transfer of electricity. the hydrogen ions are produced by consuming energy and when they reach the destination(electrode) they form hydrogen gas and give electricity.
I doubt that you get a reasonable efficiency even for short ranges. In addition, I don't see how "and give electricity" works. Sure, you can use something similar to a fuel cell, but then you lose most of the energy to radiation and finally heat.
With long ranges, you get additional losses - you would need a significant charge in that tube, the protons would repel each other and attract electrons from the environment.
No, I cannot see how this should work in any reasonable way.
A high current beam of protons or electrons is very difficult to produce, to guide and to stop it from dispersing and hitting the sides of a tube. Then you would need to get it round bends . . . . .
Metal wires do this and more so much better and need no maintenance, no vacuum and lose very little power. Were you proposing a tube to return the 'used' Hydrogen atoms back up to the other end again?
But all credit for trying to think laterally! :smile:
FAQ: Transfer of electricity wihout loss safely.
How is electricity transferred without loss?
The most common way to transfer electricity without loss is through the use of superconductors. These materials have zero electrical resistance, allowing for nearly 100% efficient transfer of electricity.
What is the safest method for transferring electricity without loss?
The safest method for transferring electricity without loss is through the use of insulated wires. This helps prevent any accidental contact with the electricity, reducing the risk of electrical shock or fire.
Can electricity be transferred without loss over long distances?
Yes, electricity can be transferred without loss over long distances using high voltage transmission lines. By increasing the voltage, the amount of current needed for transfer is reduced, reducing the amount of energy lost through resistance.
Are there any risks associated with transferring electricity without loss?
While transferring electricity without loss is generally safe, there are some potential risks. These include the production of high magnetic fields, which can affect electronic devices, and the potential for electrical arcing, which can cause damage to equipment.
How does transferring electricity without loss impact the environment?
Transferring electricity without loss can have a positive impact on the environment, as it reduces the amount of energy wasted. This helps to conserve natural resources and reduce greenhouse gas emissions from power plants.
