Transformations of exponential functions
In summary, the variables in the function y = cax - p + q have different purposes. The parameter -q is used for vertical shifts or transformations, while -p is for horizontal shifts or transformations. The variable c is for horizontal stretching and is used to change the shape of the graph from nearly straight to highly curved. When comparing y = cax with another exponential function, a is not as significant and can be ignored.
supernova1203
210
Im not sure what each of the variables do in
y=cax-p +q
my understanding is that
-q is for vertical shifts/transformations
-p is for horizontal shifts/transformations
-and c is for vertical stretching
not sure what a is for
please help?
thanks!
Try plotting two exponential functions with different a's, e.g., y=2x and y=3x, to see the effect of changing a.
well according to that, a is for vertical stretching but, if that is the case, then what is c for?
Sorry, those particular values weren't the best choices. Try looking at y=1x and y=(1/2)x as well. You'll see it's not a simple matter of vertical scaling.
Nope: 'a' is for horizontal stretching (that is,for changing the "shape", from nearly straight to highly curved). To see this, you need to make sure the vertical scale is the same in both plots, so that the value of y at x = 0 is the same in both.
RGV
In your function, y = cax - p + q, the only parameters you need to be concerned with (IMO) are c, p, and q. All of the transformations you describe can be thought of as relative to the graph of y = ax.
If you actually do need to say something about a, you need to have some other exponential function to compare y = ax with.
RGV
ohhh... its for horizontal stretching...thanks!
FAQ: Transformations of exponential functions
What is an exponential function?
An exponential function is a mathematical function in the form of f(x) = ab^x, where a and b are constants. It is characterized by a rapid increase or decrease in value as the input (x) increases.
How is an exponential function transformed?
An exponential function can be transformed by changing the values of a and b in the equation f(x) = ab^x. These transformations can result in a shift in the graph's position, a change in its steepness, or a reflection across an axis.
What is the difference between horizontal and vertical transformations of an exponential function?
Horizontal transformations refer to changes in the value of x, which affects the position of the graph along the x-axis. Vertical transformations, on the other hand, involve changes in the value of f(x), which affects the position of the graph along the y-axis.
How do you graph a transformed exponential function?
To graph a transformed exponential function, first plot the points of the original function. Then, apply the transformations by adjusting the values of a and b, and plot the new points. Finally, connect the points to create the transformed function's graph.
What are some real-life applications of exponential functions?
Exponential functions are commonly used in the fields of finance, economics, and science. They can model population growth, radioactive decay, and compound interest, among other phenomena. They are also used in computer science and engineering for data analysis and prediction.
