Trig - Addition Formula Question
In summary: So, you have(1/2)+((√3)/2-1)\tan(x)=0tan(x) = 1/2x = 30 + 180n or 210 + 180n for n = 0, 1, 2 for 0 < x < 360In summary, to solve the equation cos(x-60)=sinx, you can re-express the right-hand side as cos(90-x) and then use the trigonometric identity to simplify the equation. This results in two solutions for x in the range of 0 to 360, which are 30 and 210.
studentxlol
40
Solve the equation cos(x-60)=sinx
cosAcosB+sinAsinB
cos(x-60)=sinx
cosxcos60+sinxsin60=sinx
1/2cosx+(√3)/2sinx=sinx
How do I then solve to find x for0<x<360
cosAcosB+sinAsinB
cos(x-60)=sinx
Subtract sin(x) from both sides.
Divide by cos(x).
cosAcosB+sinAsinB
cos(x-60)=sinx
Suggestion: don't even do it this way.
You know that sin x = cos (90-x)
So re-express RHS like that:
cos (x-60) = cos (90-x)
x-60 = 90-x + 360n (where n is an integer)
2x = 150 + 360n
x = 75 + 180n
So x = 75 or 255 for n = 0 and 1 respectively. Those are the only two solutions in the required range.
cosAcosB+sinAsinB
cos(x-60)=sinx
Divide by cos(x).
Did you try what I suggested ?
What did you get ?
(1/2)cos(x)+((√3)/2-1)sin(x)=0
Now, divide by cos(x) .
[itex]\displaystyle \frac{\sin(x)}{\cos(x)}=\tan(x)[/itex] ---- Right?
FAQ: Trig - Addition Formula Question
What is the addition formula for trigonometric functions?
The addition formula for trigonometric functions is: sin(a + b) = sin(a)cos(b) + cos(a)sin(b) and cos(a + b) = cos(a)cos(b) - sin(a)sin(b).
How do you use the addition formula to solve trigonometric equations?
To solve trigonometric equations using the addition formula, you can substitute the values of a and b into the formula and simplify the expression to find the solution.
Can the addition formula be used for any two angles?
Yes, the addition formula can be used for any two angles, as long as they are measured in radians.
How does the addition formula relate to the unit circle?
The addition formula is derived from the relationships between the sides and angles of triangles on the unit circle. The formula helps to find the trigonometric values of the sum of two angles on the unit circle.
Are there any other trigonometric addition formulas?
Yes, there is a double angle formula which expresses sin(2a) and cos(2a) in terms of sin(a) and cos(a). There is also a half angle formula which expresses sin(a/2) and cos(a/2) in terms of sin(a) and cos(a).
