Trying to prove two angles are congruen to each other
  • Thread starter cse63146
  • Tags
    Angles
In summary: I've never seen this topic, but it looks really complex. That aside, I'm still not sure what you're allowed to use/not use. Are the lines parallel?I have no idea what that (parallel transport) means.
cse63146
452
[PLAIN]http://img831.imageshack.us/img831/2589/88722757.jpg
Using only the fact that the sum of the interior angles of a triangle is 180, how would I show that a = a* and b = b*?
In my diagram, there are 2 triangles: ABC and A*B*C
a + b + c = 180 and a* + b* + c =180 (a,b,a*,b,c are angles)
since both equations equal to 180, I equate them to each other and subtract angle c from both sides to get:
a + b = a* + b*.
I'm stuck here. I proved that their sum is the same, but not the angles. Do you have any suggestions?
hi cse63146! :smile:
well, they're only equal if the two lines are parallel :rolleyes:
are they parallel?
and if so, what consequences of being parallel are you allowed to use? :confused:
I'm trying to use the fact that a + b + c = 180, and somehow prove that ab and a*b* are parallel. If I can show that the two angles are congruent to another, then the lines would be parallel.
What we need is the exact wording of the problem. It's not crystal clear what you are given to work with, and what you're trying to prove.
If all you have is the picture and the fact that the interior angles of a triangle add up to 180 deg., you don't have enough information to prove either that the lines are parallel or that a and a* and b and b* are congruent.
The problem is:
Using the fact that the interior angles of a triangle sum up to 180, prove parallel transport (or PT!).
Here's the problem. In this figure, angles a and a* are as in your drawing, and b and b* (not shown in my drawing) are in the same places.
The line through the middle of the triangle is supposed to obviously be not parallel to the base of the larger triangle. Even so, a + b + c = 180 deg., and a* + b* + c = 180 deg., so a + b = a* + b*, but that doesn't tell you anything about the individual angles.
EDIT: I didn't realize my drawing would be so small. Hopefully you get the idea I'm trying to convey, anyway.
Maybe this would help. The first part is to use Parallel Transport to prove that the sum of the interior angles sum up to 180.
Now I have to do the opposite.
  • PT.doc
This whole parallel transport business needlessly complicates things, IMO. All it means is that you are going to move a copy of a line segment rigidly so that it remains parallel.
The first part of the problem boils down to this: If L || the triangle base, then a = a' and b = b'. This can be proved very quickly. If L || the triangle base, then a = the vertical angle across from a'. Since vertical angles are congruent, then a and a' are congruent. Same argument for b and b'.
The second part boils down to this: If a line L intersects the sides of a triangle (as in your drawing) so that a = a' and b = b', the L is || the triangle base. Since a and a' are corresponding angles for two lines cut by a transversal, then the two lines are parallel, hence L is parallel to the base.
I was thinking of doing something like that, but the question says that I have to use the fact that the interior angle of a triagngle sum up to 180.
Maybe it would help if I move the a*b* line somewhere else, hopefully it'll work.
(just got up :zzz: …)
cse63146 said:
The problem is:
so are the diagram, and the angles a b a* and b*, in any way mentioned in the question, or are they merely part of your attempt to answer? :confused:
if they're not mentioned in the question, you should forget them, and simply examine the definition you've been given of parallel transport
(also, try it on a sphere, where the angles always add to more than 180°, to see why parallel transport doesn't work there)
FAQ: Trying to prove two angles are congruen to each other
How do I prove that two angles are congruent?
There are several ways to prove that two angles are congruent, including using the definition of congruent angles, the properties of parallel lines and transversals, and the properties of congruent triangles.
What are the properties of congruent angles?
Congruent angles have the same measure, and they also have the same orientation and shape. This means that they can be rotated, reflected, or translated and still maintain their congruency.
Can I use the Angle-Angle-Side (AAS) congruence postulate to prove two angles are congruent?
Yes, the AAS congruence postulate states that if two angles and the included side of one triangle are congruent to two angles and the included side of another triangle, then the two triangles are congruent. Therefore, if two angles are congruent, and they are also included in two triangles, then the triangles are congruent, and so are the angles.
What is the difference between congruent angles and similar angles?
Congruent angles have the same measure and shape, while similar angles only have the same shape but can have different measures. Congruent angles are also identical, while similar angles are proportional to each other.
How many pairs of congruent angles do two parallel lines and a transversal form?
Two parallel lines and a transversal form four pairs of congruent angles, known as corresponding angles, alternate interior angles, alternate exterior angles, and consecutive interior angles.
