- 18,988
- 14,442
Guess I have to add, "for me." ##$$@@%% multiple platforms.Bystander said:It's in "Info."
btw, it should also be at the very bottom called "terms of service"phinds said:OK. Thanks
Ah, don't worry about it. Nobody pays any attention to you anyway.Bystander said:Guess I have to add, "for me." ##$$@@%% multiple platforms.
OK. I don't see that either so I assume you mean you're working on both.Greg Bernhardt said:btw, it should also be at the very bottom called "terms of service"
phinds said:But I don't GET anything when I click on info. Again, the "info" dropdown selection just opens the main page of PF (well, OK, that's SOMETHING ... but not much)
OK, got it. Thanks.anorlunda said:The known issue is caused by screen magnification. Use CTRL-minus sign to zoom out, until INFO becomes part of the top bar, then it will work.
I have a huge display, I just have poor eyesight. I have new glasses lenses on order which will probably fix the problemjtbell said:Maybe you can use this as an excuse to buy a bigger display.
Info now links to the rulesphinds said:OK, got it. Thanks.
@Greg Bernhardt , can this still be fixed or is it hopeless due to the magnification? I mean, I SEE the "info" at magnification but it just doesn't do anything.
Ah ... so it does. Thanks.Greg Bernhardt said:Info now links to the rules
ZapperZ said:Considering how important the PF Rules are, and how often they are invoked in the running of this forum, I expect that a directly link to it should be front and center, rather than being buried under "INFO". Instead, less important items such as "VIDEO", "PHYSICS NEWS", etc...etc. have their own directly links.
The rules for this website can be found by clicking on the "rules" link, which is usually located in the top or bottom navigation bar of the website. These rules may vary depending on the specific website, so it's important to refer to the rules of the specific website you are using.
The "rules" link is important because it outlines the guidelines and expectations for using the website. It helps to ensure a safe and respectful online environment for all users.
The "rules" link is usually located in the top or bottom navigation bar of the website. It may also be found in the website's footer or in a separate "About" or "FAQ" section.
If you don't follow the rules of the website, you may face consequences such as being banned from the website or having your account suspended. It's important to read and follow the rules to avoid any negative repercussions.
No, the rules for each website may vary. It's important to read and follow the specific rules for the website you are using, as they may be different from other websites.
