Undergraduate Major: Engineering vs Math/Physics
In summary, Skychase is considering a career in research and does not know if it is the best option for him. He has taken a good amount of math classes and enjoyed them, but he is not interested in a specific area of math and physics and is more interested in a diverse array of areas. He is considering continuing his engineering studies while taking graduate math and physics classes to use the theoretical aspects of math and physics. He is unsure if working as an engineer allows him to use the theoretical aspects of math and physics. He would be better off doing mathematics and physics and continuing down the research/phd path.
SkyChaser
So, I'm trying to decide which career to go into. I've already taken a bunch of high-leveled theoretical math and physics classes, and I've enjoyed and done well in them so far. However, I'm not specifically interested in a specific area of math and physics, mostly interested in a diverse array of areas, so I'm not sure if a research career would be the optimal choice for me since I would have to go into a specific field.
Would it be viable for me to continue doing engineering physics while taking graduate math and physics classes? Does working as an engineer allow me to use the theoretical aspects of math and physics as well? Or am I better off doing math and physics and continuing down the research/phd path?
hey skychase, and welcome to pf! what math classes constitute "high-leveled theoretical"? what specifically have you taken, as this will shed light on what could be the best option for you. this being said, what do you plan on doing after graduation?
Hi. I have taken honors analysis I, II, linear algebra, abstract algebra, differential geometry, topology, algebraic topology, complex analysis, and taking graduate real analysis and linear algebra.
I really do not know what I plan on doing after graduation. I'm currently a first term sophomore and really enjoy doing theoretical math and physics, but I'm not sure if I'd enjoy doing it for a long time as a career. On the other hand, engineering seems like a likely route for me to apply my math and physics skillset as a whole, rather than gaining strong expertise in one specific field in research.
okay, so you have indeed taken a good amount of math (I wasnt sure if you were referring to first year calc and diff eq). this being said, i think you've answered your own question:
you probably shouldn't set to become a mathematician if youre losing interest. I'm actually a graduate engineering student (mechanical, specifically fluids) although my undergrad was in math. from experience, engineering at the graduate level (far different from undergrad) has what you're looking for. classes are heavy with vector/tensor calculus, PDE's, and also use the physical intuition that physics enjoys. linear algebra is prevalent, and complex analysis manifests itself too.
however, this is simply the academic side. after you get your degrees (and phd or masters should you decide to) all engineers i talk to and have researched with say the "real world" is totally different. all the analysis is a right of passage, but is not practiced.
i'm sure some exist that use the theory in a deep way like we do in school, but i have never met one.
hope this helps!
i should say, this includes the "hot shot" engineers at boeing I've talked with.
Would I be better off simply doing mathematics and physics as a career and work in a national lab without having to work in academia since I'm only interested in research? I suppose I could work in a field that incorporates interdisciplinary field like quantum gravity. I don't think engineering really uses modern physics such as gr and qm as much, do they?
these questions are good ones, but for sure i cannot answer them entirely. the best way to know is to start contacting some engineers and working professionals (perhaps starting with your professors). see if your professors are conducting research and if you can help. it definitely isn't for everyone. i recommend trying research first.
FAQ: Undergraduate Major: Engineering vs Math/Physics
What is the difference between studying Engineering and Math/Physics as an undergraduate major?
Engineering and Math/Physics are both highly technical fields, but there are some key differences between the two. Engineering focuses on the practical application of scientific principles to design and create solutions to real-world problems. Math/Physics, on the other hand, is more theoretical and focuses on understanding and explaining the fundamental laws of the universe.
Which major has better job prospects?
Both Engineering and Math/Physics are in high demand and offer excellent job prospects. However, Engineering graduates may have a slight advantage as their skills are more directly applicable to specific industries and job roles.
Do Engineering and Math/Physics majors have similar coursework?
While there may be some overlap in coursework, the two majors have different focuses and therefore have some distinct courses. Engineering majors will take classes in their specific discipline (e.g. mechanical engineering, chemical engineering) as well as general engineering courses. Math/Physics majors will take a variety of math and physics courses, with some flexibility to choose specific areas of interest.
Which major is more challenging?
Both Engineering and Math/Physics are challenging majors, but in different ways. Engineering requires a strong foundation in math and science, as well as practical problem-solving skills. Math/Physics requires a deep understanding of complex mathematical and physical concepts and the ability to apply them to theoretical problems.
Can I switch from one major to the other?
It is possible to switch from one major to the other, but it may require additional coursework and may delay graduation. It is important to speak with an academic advisor to determine the best path for your individual goals and interests.
