Understanding Degenerate Eigenvalues and Vectors in Math Operations
  • Thread starter bon
  • Tags
    Operators
In summary, the basic math operators are addition (+), subtraction (-), multiplication (*), and division (/). Parentheses are used to group numbers and operations together in a specific order, with the operations within the parentheses being performed first. The order of operations in math is PEMDAS, and the difference between the division operator (/) and the modulus operator (%) is that the former gives the quotient while the latter gives the remainder. Finally, the exponent operator (** or ^) is used to raise a number to a certain power.
bon
559
please see attached
Ok so I've done A and have worked out eigenvalues and vectors of H and B
For H I get 4 possible eigenvectors (1,0,0) (0,1,1) (0,0,1) and (0,1,0) . The q is why does neither matrix uniquely specify its eigenvectors? I guess the answer is because the eigenvalues are degenrate (repeated)..but is there a clearer explanation as to why?
Thanks
  • maths q.pdf
Also - i can't seem to find three common eigen vectors.. I can only find (1,0,0) and (0.1.1)
anyoneeee?
why can't i find three common eigenvectors?
for providing the attached information. Degenerate eigenvalues and vectors occur when there are multiple eigenvectors associated with the same eigenvalue. In other words, the eigenvalues are repeated, resulting in multiple possible solutions for the eigenvectors. This can happen when the matrix is not diagonalizable, meaning it cannot be transformed into a diagonal matrix with distinct eigenvalues. In your case, the matrices H and B do not have distinct eigenvalues, leading to multiple possible eigenvectors. This can also occur when there are repeated factors in the characteristic equation, resulting in repeated roots. The reason why the matrices do not uniquely specify their eigenvectors is because the eigenvectors are not unique due to the degenerate eigenvalues. I hope this helps clarify the concept of degenerate eigenvalues and vectors in math operations.
FAQ: Understanding Degenerate Eigenvalues and Vectors in Math Operations
What are the basic math operators?
The basic math operators are addition (+), subtraction (-), multiplication (*), and division (/).
How do I use parentheses in math expressions?
Parentheses are used to group numbers and operations together in a specific order. The operations within the parentheses are performed first, followed by any remaining operations.
What is the order of operations in math?
The order of operations in math is PEMDAS, which stands for Parentheses, Exponents, Multiplication and Division (from left to right), and Addition and Subtraction (from left to right).
What is the difference between the division operator and the modulus operator?
The division operator (/) gives the quotient of a division while the modulus operator (%) gives the remainder of a division. For example, 10 / 3 = 3.33, while 10 % 3 = 1.
How do I use the exponent operator in math?
The exponent operator (** or ^) is used to raise a number to a certain power. For example, 2 ** 3 = 8, meaning 2 raised to the power of 3 is equal to 8.
9K
