Understanding Eigenspaces and Eigenvectors
  • Thread starter flyingpig
  • Tags
    Concept
In summary, the conversation discusses the eigenspace and eigenvectors of a matrix A, given the equation A\boldsymbol{x} = \lambda\boldsymbol{x}. It is stated that the eigenvectors form a linearly independent set, assuming that A\boldsymbol{x} - \lambda\boldsymbol{x} = \boldsymbol{0} has a nontrivial solution. The process of finding eigenvalues and eigenvectors is also briefly mentioned.
flyingpig
2,579
Suppose [tex]A\boldsymbol{x} = \lambda\boldsymbol{x}[/tex] and [tex] A\boldsymbol{x} - \lambda\boldsymbol{x} = \boldsymbol{0}[/tex]
Then the [tex]\boldsymbol{x}[/tex] (vectors) that form the eigenspace are the linearly independent set of eigenvectors assuming [tex] A\boldsymbol{x} - \lambda\boldsymbol{x} = \boldsymbol{0}[/tex]
It's true right? It's just solving the nullspace and then naming the new solutions as eigenvectors.
yes
solving [itex] det(A-\lambda I) [/itex] will give you the allowable values for lambda (eigenvalues of A)
yes
then for a given [itex]\lambda [/itex], solving [itex]Ax = \lambda x [/itex] for non-trivial x, will give you the corresponding eigenvectors for that eigenvalue
FAQ: Understanding Eigenspaces and Eigenvectors
What is a concept check?
A concept check is a method used to assess understanding of a concept or topic by asking questions that require a true or false response.
How is a concept check different from a regular check for understanding?
A concept check focuses specifically on a single concept or topic, whereas a regular check for understanding may cover multiple concepts or topics.
What is the purpose of a concept check?
The purpose of a concept check is to ensure that individuals have a solid understanding of a concept or topic before moving on to more complex material.
Are concept checks only used in science?
No, concept checks can be used in any subject or field to assess understanding. They are commonly used in science due to the complex nature of many scientific concepts.
How should concept checks be used in a learning setting?
Concept checks should be used periodically throughout a lesson or unit to gauge understanding and identify any areas that may need further clarification. They can also be used as a formative assessment tool to guide instruction.
