Understanding Feed Forward Controllers for Active Steering Systems
  • Thread starter Jones1987
  • Tags
    Controller
In summary, the conversation is about designing a control system for an active steering system and the need for a feed forward controller. The purpose of a feed forward controller is to anticipate changes and make adjustments before they actually occur. It is commonly used in process units, such as in distillation, to maintain stable operation. The person asking for help is unsure how this concept applies to their specific project and is seeking further clarification.
Jones1987
77
Hi,
I'm trying to design a control system for an active steering system. I have the feedback loops setup fine, and the PID controller. I'm not sure how to get my reference model to work, but I'm thinking I might need a feed forward controller, however I can't seem to find any good material that fully explains what this is to me.
Anyone mind helping?
Thanks
Feed forward is simply going to be a way to tell the controller to go ahead and make an action instead of waiting for the measurment in the PID controller to change.
I work in a process unit which has lots of distillation. A typical feed forward variable which is integrated into a controller (more complicated than a simple PID) would be something like the feed rate to a tower. As feed increases, there are things that will have to happen, such as adding heat. The tower can add heat as soon as it starts to see feed increase in the piping upstread of the tower, instead of waiting for the actual trap temperatures to drop. This means much more stable tower operation, which is good for production in a number of ways.
Basically it's going to be a way to bias a controller for something before it actually "happens." I'm not sure how that will apply to your active steering. If you can be more specific, than maybe I can as well.
FAQ: Understanding Feed Forward Controllers for Active Steering Systems
What is a feed forward controller?
A feed forward controller is an electronic device or software algorithm that uses a predefined input signal to predict and adjust the output of a system in order to achieve a desired response. It is commonly used in control systems to compensate for errors caused by disturbances or changes in the system.
How does a feed forward controller work?
A feed forward controller works by using a mathematical model of the system to estimate the output based on the input signal. The estimated output is then compared to the desired output and any discrepancies are used to adjust the control signal in order to minimize the error and achieve the desired response.
What are the advantages of using a feed forward controller?
The main advantage of using a feed forward controller is that it can quickly respond to changes in the system without relying on feedback from the output. This allows for more precise control and can prevent instability in the system. Additionally, it can reduce the effects of disturbances and improve the overall performance of the system.
What are the limitations of a feed forward controller?
One limitation of a feed forward controller is that it relies on accurate modeling of the system, which can be difficult to achieve in complex systems. Additionally, it cannot compensate for unmeasured disturbances or changes in the system, which may lead to errors in the output. In some cases, a combination of feed forward and feedback control may be necessary to achieve optimal performance.
Where are feed forward controllers commonly used?
Feed forward controllers are commonly used in a variety of industries, including manufacturing, robotics, and aerospace. They can be found in applications such as temperature control, motion control, and process control. They are also commonly used in electronic devices such as audio amplifiers and motor controllers.
