Understanding Force Relationships: F_A & F_B
In summary, the problem is asking for the minimum tension in a rope when two forces are not components of the result. The solution can be found when θ is set to 90°.
fee
http://img221.imageshack.us/img221/604/yesor.jpg
My question is: how would I know that F_B has to act perpendicular to F_A? Are there any rules or is there any logic that I am supposed to know?
Just trig - work out what the force is for different relative angles.
note: cos(30) = sin(60) = (√3)/2, cos(60) = sin(30) = 1/2.
if x=Fa and y=Fb; you need (√3)x/2 + ycos(θ)=10kN, and x/2 = ysin(θ)
... which is how you'd intuitively do the problem.
So solve for y as a function of theta, and find the minimum.
This is the same as saying that x and y are components of the result - where x forms an angle of 30 degrees. Since they are components, they must for a rt-angled triangle.
In my opinion, No, you should not be expected to know that. However, setting up the problem using an arbitrary value for θ. Then the solution should show that the minimum tension occurs when θ = 90°.
I'd agree with SammyS - unless it was explicitly in your course-notes ... maybe earlier in the book the problem comes from?
Some teachers like to give problems that students have to explore then show the short-cut in the model answers. Much like this does in fact.
There is a logic to it - if the two forces are not components of the result, then more of each force gets "wasted".
But you'll only "see" it by playing around with the forces.
Thank you very much, that was extremely helpful.
I don't think I understand how the conclusion in the picture is intuitive. I will post my chain of reasoning given my interpretation of the original post's problem and ask whether or not someone could find the precise flaw.
∵ We need the sum of the x components of vector U and vector V to equal a value C, and we would like for V to be at the least possible value.
∵ We cannot change the magnitude or angle of vector U,
∵ U·cos(30°) is the x component of U,
∵ V·cos(θ) is the x component of V,
∴ U·cos(30°) + V·cos(θ) = C,
∴ V·cos(θ) = C - U·cos(30°).
∵ Let D = C - U·cos(30°),
∴ V·cos(θ) = D,
∴ V = D/cos(θ),
∴ V = D·sec(θ).
∵ sec(θ) is at its minimum when θ = 0° with 0° ≤ θ < 90°,
∴ V is at its minimum when θ = 0° with 0° ≤ θ < 90°.
However, this contradicts the conclusion reached by the post. Could somebody assist me?
∴ V·cos(θ) = D,
∴ V = D/cos(θ),
∴ V = D·sec(θ).
I don't see anywhere in your working of the problem that you used the y components of the vectors.
U·sin(30°) - V·sin(θ) = 0
Oh! I completely forgot that there wasn't supposed to be any acceleration in the y component. My apologies.
FAQ: Understanding Force Relationships: F_A & F_B
What is the definition of force?
Force is a physical quantity that is used to measure the amount of push or pull on an object. It is a vector quantity, meaning it has both magnitude and direction.
How is force related to motion?
According to Newton's First Law of Motion, an object at rest will remain at rest and an object in motion will continue in motion at a constant velocity unless acted upon by an external force. This means that force is required to change an object's state of motion.
What is the difference between F_A and F_B in force relationships?
F_A and F_B refer to two different forces acting on an object. F_A is the force applied to the object, while F_B is the force exerted by the object. In other words, F_A is the external force acting on the object, while F_B is the internal force generated by the object itself.
How do you calculate the net force in a system?
To calculate the net force in a system, you need to add up all the individual forces acting on an object. If the forces are in the same direction, you simply add them together. If they are in opposite directions, you subtract the smaller force from the larger force to get the net force.
What are some examples of force relationships in everyday life?
Some examples of force relationships in everyday life include pushing a shopping cart, throwing a ball, and riding a bike. In each of these scenarios, forces are acting on the objects to cause them to move or change direction.
