Understanding Gravity at Long Distances
  • Thread starter Deepak K Kapur
  • Tags
    Gravity
In summary, the conversation discusses the concept of gravity at long distances, particularly in relation to stars, constellations, and galaxies. It is explained that while the star next to the sun may not have a significant gravitational influence on it, the overall distribution of stars in the galaxy affects the motion of each star. The formation of constellations and clusters of galaxies is attributed to the cumulative effect of gravity over long periods of time. It is also noted that even objects at the boundary of a galaxy can still exert gravitational influence on objects in other galaxies, though the effect may be small due to the vast distances involved.
Deepak K Kapur
164
Understading Gravity at Long Distances
Hi all,
I have a simple curiosity and expect some simple answers.The star next to Sun does not have much gravitational influence on it. If it would have any influence it would have been felt by planets also. My questions are,1. Then how do stars in a constellation stay together when they possibly cannot influence each other 'much' because of the huge distance between them?
2. How do clusters of galaxies form when there are utterly enormous distances between them?
In other words, the stars that are at the boundary of a galaxy do not have any 'power' to influence the boundary stars of a galaxy that is very very far away from them. So how do galaxies interact with each other?
Welcome to PF;
I can try to provide simple answers but sometimes more complex answers are easier to understand.
Bear in mind that "a simple curiosity" is what got the likes of Galileo into so much trouble.
The size of the effect of alpha centauri on the solar system is only small in comparison with other effects much closer. In general, the motion of each star in the Milky Way is broadly determined by the overall distribution of the other stars. All those little effects add up.
There is nothing special holding constellations together.
The constellations are just patterns that our mind sees in the sky. There is no special relationship between the stars that holds them in their constellations and the patterns will change over time as different stars are moving at different speeds.
There are also extremely large masses involved, and not much else to interact with.
The gravitational attraction only needs to be bigger than whatelse is out there ... which would be: other galactic clusters and cosmological expansion.
Consider an analogy -
You can have small eddies in a large whirlpool.
The overall flow of the whirlpool does not affect the motion of a bit of water in an eddy about the center of the eddy ... but it does act to keep lots of little eddies moving together about the center of the whirlpool.
I think you are thinking along the edge of something pretty deep though.
Something like:
http://phys.org/news/2011-06-universe-clumpier-thought.html
They are not staying together. They are moving in random directions, but the absolutely vast distances between us and the other stars mean that you can only see this movement with very very accurate instruments or over very long periods of time. Only after 100's to 1000's of years would there be any perceptible change in the constellations that you could see with the naked eye.
Plus, as Simon said, practically no stars in a constellation are gravitationally bound to each other. It's kind of like looking into a field full of fireflies that all light up at the same time. From your point of view some fireflies LOOK closer to others, but in reality they could be separated by the entire field.
Lots of gravity added up over LONG LONG LONG periods of time.
Sure they do. Gravitation has no limit in range. The stars on the boundary of a galaxy influence everything else in the universe. It's just that the further away the stars are from an object, the less their gravity influences them.
Ah, but it does have some. And this is felt by the planets also. The galaxy is held together by gravity, and yes, this force is very weak compared to the gravity we feel from the Earth. As Drakkith said, the galaxy forms over a very long time. And similarly the density of the galaxy is very small (compared to what we are used to here on Earth). In a way, you can think of the galactic gravity as happening on a completely different scale than the solar gravity. It is the same mechanism (gravity), but on different scales.
You can broadly say that every two masses in the Universe will be interacting, gravitationally. In each case, it's just a matter of scale. The effect of one galaxy on another is very small - just enough to deviate their paths by a tiny amount. The Sun affects the paths of the Moon and the Earth, they also, mutually affect each other and a rock in orbit around the Moon will also be subject to Sun, Moon and Earth (and vice-versa, of course). The tight orbit of the rock around the Moon is because of the close proximity. If the rock were 150million km from an isolated Moon (same distance as from the Sun now), the 'year' would be tens of thousands of Earth years long.
The Inverse Square Law will give the right answer for describing what happens in most circumstances.
Fun fact: the gravitational force between Earth and pluto is weaker than the force between Earth and Alpha Centauri, 4 light years away.
All objects in the solar system are pulled a bit towards Alpha Centauri (with ~10-13 cm/s2) - as the acceleration is nearly the same for all objects, we cannot measure this.
If you combine the gravitational effects from all stars (and other matter) in our galaxy, this is sufficient to keep our sun on a slow circular path - we need 250 million years per revolution!
Another fun fact, which knocks Astrology on the head: the gravitational force from the Midwife's mass is greater on a newly born baby than the gravitational force from any of the planets or nearby stars.
as if astrology needed knocking. hehe. That's an interesting fact that Pluto's force on Earth is less than Alpha Centauri's. I would have intuitively expected Pluto's to be more.
Does it mean Gravity is classical and not quantum mechanical?
Does it mean that a star can influence another star in due course of time even if they are infinite distance apart?
1. Consider that the stars are not infinitely apart but are hugely apart. When viewed from the angle that gravity is just the curvature of space time, what kind of a curvature of space is in action when the stars are so much apart that the space between them extends to huge distances and is flat for all purposes and it takes even light gazzillions of years to travel between them? I think there would be no action between such stars even if we wait for gazillions of years to pass.
By the same reasoning, it seems to me that galaxies cannot influence each other significantly as to cluster together.
2. Suppose a galaxy has gravitational influence up to say 5 light years. To my mind, it cannot influence another galaxy that is say 10 light years away from it even if we consider that huge amount of time has passed. It's because the first galaxy cannot 'extend' its influence beyond 5 light years. A galaxy having 'Gravity that has no limit' would require that the galaxy has infinite mass, it seems.
There is no such distance cutoff and the force of gravity (classically, which is what we're talking about here) does extend out to infinity.
The gravitational force between two objects is given by ##F=\frac{Gm_1m_2}{r^2}## where ##G## is a constant, ##r## is the distance between them, and ##m_1##, ##m_2## are the masses. As ##r## increases, the force gets weaker, but it never disappears completely - even when both masses are finite.
As Nugatory said, gravity does have no limit, even though it does get less with distance. If it helps, imagine the galactic cluster as some continuous object which has a coarse-grained density as a function of position. The density of this 'object' is great enough for gravity to hold it together. (Well, actually, only if we include the dark matter, but that is a different discussion). And by 'coarse-grained', I mean when we use a density that is averaged over nearby galaxies. If we used a 'true' density, then it would be a Dirac delta function at the position of each galaxy. The reason to coarse-grain is because it makes calculation simpler. Also, that way it gives an intuitive way to think about the galactic cluster, rather than as a bunch of Dirac-delta functions, which I think is where you are having trouble imagining how they can all hold each other together via gravity.
We only have (successful) classical models for gravity so far.
Quantum gravity is still a work in progress.
Therefore, all these answers have been in terms of classical theory.
Define "infinite".
Extremely distant events will hit causality limits in general relativity: they are "over the horizon of the Universe" so to speak and their influence may never be felt here due to the cosmological expansion.
You realize that "action" is a technical term in physics right?
Basically, there is nothing in GR to suggest that the kind of absolutely flat space-time you are thinking of exists. Spacetime that we see is, overall, very flat - but not absolutely flat. Gravity certainly acts across the entire universe that we know about.
That's roughly 46 billion ly radius (visible).
That "for all purposes" has limits to it - for all whose purposes? - there will be some purposes where the small curvature present is not sufficiently flat. Generally it is too much work to take account of every object in the Universe when we do our calculations so we make approximations in the hope that local events have an influence that far outweighs anything "out there". This is often, but not always, OK. In cosmology, for eg. you seldom get away with it.
And yet they do - so, either the consensus of physics for the last few decades is wrong and you are the first to notice or there is something wrong with the reasoning.
That would be a pointless supposition since galaxies do have gravitational influence many more than 5ly.
Our own galaxy, by itself, is 100-120,000ly across and held together by gravity - so the influence of gravity extends some 5 orders of magnitude farther than you would have anyone suppose.
You seem to be having trouble with the sorts of distances that are on the cosmological scale.
The current models for gravity account for the long-range effects well enough to be useful for modelling large scale structures like galactic clusters. I'm sorry that this seems impossible "to your mind" - it happens to be true.
It is often said that atom/matter is 99.9999999% empty. My questions are:
1. When Earth is hugely empty, how can it have gravity?
2. Gravity is negligible at the scale of sub-atomic matter. How do all these small effects of nucleons, electrons etc. (that make up matter) add up to form total gravitational field of the Earth? Are they really responsible for this gravity, when we say that they have wave nature associated with them?
The bits in between the empty spaces are incredibly dense - that's why. The overall mass is what it is and produces the gravitational field that you'd expect.
1. it is as sophiecentaur said. The atom is mostly empty, but the bit that is not empty is extremely dense. Have you heard of a neutron star? that is what happens if you remove the empty space. very dense.
2. yes, if you add up all the matter of the nucleons and electrons in the entire earth, then it should add up to the known mass of the earth. (this is a simple calculation for a neutron star, its density is roughly the same as the density of an atomic nucleus). And yes, gravity is not (so far as we know) compatible with quantum physics. But mass is fairly well explained in quantum physics, so we can calculate the mass of a bunch of particles. And we can say that a very large bunch of particles produces a gravitational field that affects their overall motion. But on the other hand, exactly how gravity affects one particle (quantum-mechanically) is a bit... not well known at this point.
@Deepak: lots of very small things can add up to a very big effect.
You seem to be having a lot of trouble believing this. Is that the case?
A lot of the answers to your previous questions were about this - galaxies a long way apart have a small effect on each other, but there are lots of galaxies and lots of time for things to happen in so all those small effects add up to the big effects that we see. It is the same at any scale.
Gravity has a very small effect at the atomic scale in comparison with the other stuff that goes on there. But it does have an effect - there are lots of atoms and they all add up just like you can get to any number, however large, by repeatedly adding the same small increment.
Personally I would discourage the idea that matter is mostly empty space - it tends to mislead people into thinking weird stuff like that it should be possible to push two objects through each other. I'd point out that fishnets are mostly holes too, but that doesn't stop them catching fish. Matter is mostly electromagnetic field with some other fields thrown in for good measure.
I can see you are having fun with these questions, but are you paying attention to the answers? Have you learned anything?
I am not asking questions for the sake of fun but I really want to understand things:smile:. I surely am learning a lot.
I have heard that light takes millions of years to come from the core of the sun to its surface as the sun has huge density.
1. Then how come a photon can come out of the nucleus almost instantaneously, when nucleus is very very dense?
2. If we assume that gravity is ultimately made up of small discrete units (may be gravitons), how come these small units come out of a nucleus/black holes/neutron stars etc., when they themselves suck in everything ( in case of black holes).
I mean to say if light cannot escape from a black hole, how can gravity (either in discrete units or as waves) itself escape from such a huge amount of mass? It seems to be a wrong question but I just want to clarify things!
Well, it will help you learn better if we stop just spoon-feeding you answers, and start getting you to reason your way through to the answers yourself ... you seem to have the ability...
Where from - when you hear something, it is useful to say where you heard it. I heard that the Sun went extinct a long time ago and the government is covering it up.
http://en.wikipedia.org/wiki/Solar_core
... according to that article, what are the factors that contribute to the time it takes for a photon to travel from the core to the surface? Is it just the density? Or is the overall size also important?
Considering the factors from your reading (above) - how does the relative size of the Sun compared with an atomic nucleus factor into the time for a photon to emerge?
Is a graviton usually considered to be a unit of gravity, or a particle that mediates the gravitational force?
What is the difference?
That is something that a quantum theory of gravity has to explain :) we don't have one of those.
Why would a graviton experience gravity - it is gravity?
Anyway: We use general relativity instead - where gravity is described by a different mechanism.
@Deepak
If you want an answer to your question which involves Newton's ideas then you would not get an answer which is consistent with modern Cosmology. He assumed an infinite, stable universe without relativity or QM. So you can only get a partial answer in classical terms.
It can be counter productive to ask questions that pinpoint inconsistencies in our state of knowledge. Our knowledge is full of inconsistencies - that is a given and always will be. You can start by assuming an inverse square law but that must fall down when considering effects where the distances are of the order of c and the age of the Universe. All models have to involve a bit of a fudge in places - for instance, the conclusion that there must have been 'Inflation' in the period just after the Big Bang. That's really not aesthetically pleasing to brains that favour simple formulae with just three terms in them. But we're stuck with it - until a better (more pleasing or more accurate) idea comes along.
Your question:
Would a satisfactory comment to this be that the formation of a black hole is essentially a slow process and the gravitational situation is part of the structure itself. EM radiation (the radiation we can detect, at least) involves quicker changes such as light or radio waves? (And we haven't yet detected gravitons, of course). One could possibly expect the situation to be different at very low frequencies. (In any case, Hawking Radiation is a predicted form of EM radiation that can 'escape' from black holes - so there is even a way out for EM energy)
sophiecentaur said:
@Deepak
Your question:Would a satisfactory comment to this be that the formation of a black hole is essentially a slow process and the gravitational situation is part of the structure itself. EM radiation (the radiation we can detect, at least) involves quicker changes such as light or radio waves? (And we haven't yet detected gravitons, of course). One could possibly expect the situation to be different at very low frequencies. (In any case, Hawking Radiation is a predicted form of EM radiation that can 'escape' from black holes - so there is even a way out for EM energy)
I do not always think about extreme cases in science but very simple scenarios.Most of the people tell me that I am asking a 'why' question that is very difficult/impossible to answer. I reply that in many cases a why question can easily be changed to a how question. I give a few examples below:
1. Why inertia? can be changed to How is a body able to move for infinite time in the absence of any force?
2. Why are electrons all the same? can be changed to How is it that no electron differs from any other electron even if we consider gazillions of them?
3. Why this universe? can be changed to How is it that we have this universe instead of nothing?The above 'how' questions do not deal in extremes but are very simple questions.
Similarly, when I ask that how can a nucleus/proton/nucleon/quark etc. that is extremely dense allow the emission of a photon, I am simply stating a curiosity, which I think cannot be counter-productive.
On the same lines I ask the following:
If we have a very huge concentration of electromagnetic 'energy', I suppose (may be wrongly, do correct me!) even that would not allow things to escape from it. Here, we don't need the usual concept of gravity, as matter is not involved.
So, it seems something else is the cause than gravity rather than just matter. BTW its just my imagination, which I think shouldn't be counter-productive even if it's wrong.
I think that you are misleading yourself if you claim you are not dealing with "extremes" when you ask these questions. The all represent great extremes from our everyday conscious observations of the world around us. They take you way outside the realm of Newton's Science and you can't look for answers in School Science. You have to be prepared to accept some new things, along with a new framework of thinking, without referring back to what you are comfortable with. It's much harder than that.
They are not very simple. They cannot be answered in physics. Those are just observations.
Gravity is an effect of energy. It does not matter which type of energy.
Ok, I somehow agree to what you are saying, that I ask the wrong questions.
But, coming back to the original question of gravity acting at long distances,
Pluto moves in and out of the sun's gravity by all practical means. Once it gets out of the gravitational field (or we can say that the effect of the sun's gravitational field diminishes to a great extent for pluto), how does it continue to move in its orbit?
Now, suppose it is about to enter the sun's gravitational field, how does pluto 'communicate instantly' with that field when the gravitational field of 'pluto' itself will take many hours to reach sun. I think unless two objects are not in 'contact' with each other via gravitational waves, they cannot influence each other?
Does it mean, gravity has infinite speed of propogation?
Don't tell me I got this also all wrong:eek:
It doesn't get out of the Sun's gravitational field, and even at the outer extreme of Pluto's orbit the gravitational field is quite strong enough to keep it in orbit. This isn't a matter of guess-work, you can calculate it for yourself using Newton's gravitational law ##F=\frac{Gm_1m_2}{r^2}## for ##r## corresponding to Pluto's nearest approach to the sun and again for ##r## corresponding to Pluto's greatest distance from the Sun. (google will find you the values of ##G##, ##m_1##, ##m_2##, and the extreme values of ##r## pretty quickly).
Does it mean, gravity has infinite speed of propagation?
No. Because Pluto never left the the Sun's gravitational field, it never had to reenter it, was always continuously interacting gravitationally with the sun.
It does occur to me... You might want to try googling for "escape velocity" (and look at the math behind it too!). Although an object in orbit around the sun can never leave the sun's gravitational field (because that field extends out to infinity) an object moving away at escape velocity will never fall back to the sun. Pluto at all points in its orbit, is moving at less than escape velocity.
Do not confuse things by introducing gravitational waves and the speed of propagation of gravity (it is c, the speed of light, BTW) until you understand the classical Newtonian picture. That's like trying to build the second floor of a building before you've built the first floor - it doesn't work, and if you keep on trying to do it you'll just prove that you don't understand what a building is.
Scenariios that are simple to say may still be extreme and complex in their physics.
This is correct - when you change the words you often change the question.
If you mean to ask "how" then, for clarity, you should do so.
But: as I told you before - it is not the word "why" that is being objected to, but a type of question.
Did you read up about empiricism and the problem of induction like I suggested?
If you like we can agree to interpret your questions in terms of mechanisms and processes in the future and so avoid further clogging up this thread with philosophy. But you will have to agree not to keep reasking "why..." whatever the answer was.
I have shown you in my previous post how you will best approach that question. If you are serious about learning instead of just asking questions for the sheer joy of asking, then you will have read the references I gave you and you will be able to answer the questions I gave you.
"The usual concept of gravity" then, would be the Newtonian one. Newtonian gravity requires mass.
What was the question?
"Something else is the cause" of what?
...coming back to the original question of gravity acting at long distances,
This has been answered before. Gravity does not have a range - it goes on forever. Pluto can never move out of the Sun's gravity and the Sun can never move out of Pluto's gravity.
You insisted you are learning - and yet you repeat the same mistakes.
Don't tell me I got this also all wrong :eek:
Please reread the thread to see how these questions have been answered before.
Please answer the questions put to you in the replies too - those are not rhetorical, but are designed to guide you to learn better.
Since you don't appear to learn best by just being spoon-fed the answers, I want to encourage the others replying in this thread to adopt a more Socratic approach with you to guide you to discovering the answers for yourself.
I was deliberately not answering those questions because my answer may further complicate the matter.
For example my answer to your question,
will be as follows:
The difference will certainly be there because 'a unit of gravity' can simply be a' concept' introduced to make things easier but 'a particle that mediates' has to move greater than the speed of light to come out of a black hole.
I state even further. if you say the particle is 'imaginary' ( something only virtual), my next question would be,
what is the difference between a 'concept' and 'a virtual mediating particle'?
Gravity does not "come out of a black hole". It's a field, it was there before the star collapsed into a black hole, and it's still there after the collapse. Indeed, the gravitational field of a large star is identical to the gravitational field of a black hole of the same mass everywhere above the surface of the star.
You really have to nail down your understanding of classical Newtonian gravitation first.
Without that foundation, you'll just find yourself drifting from one misconception to another (so far in this thread, you've suggested that it's possible to move "beyond the range" of gravity; that gravitational waves have something to do with gravitational attraction; and now that gravitons are particles moving outwards from a gravitating object).
With that foundation, you'll be able to answer the question that started this thread, about gravity and extreme distance; and you'll be able to build on that foundation to understand much more of modern physics.
Unfortunately not answering the questions just means that we are unlikely to be able to help you.
Is a graviton usually considered to be a unit of gravity, or a particle that mediates the gravitational force? What is the difference?
will be as follows:
That's great - because it tells us a lot more about how you are thinking about the relationship between gravitons and gravitational fields.
You didn't actually answer the question, but it gives us something to go on and highlights a fundamental misunderstanding. It tells us that you don't know what a graviton is usually considered to be so you have combined concepts that belong to two separate models.
You needed to go look it up and report back what you discover.
Do it now. Google helps here.
Note: when you see a phrase like "is usually considered" you should immediately ask (yourself) "by whom?" - in this case, the answer would be "by established physics". That's why you needed to look it up: I wasn't asking you to tell me what you thought it was but what everyone else thinks it is.
I suspect you also don't know how virtual particles can mediate forces or why the particles are called "virtual" in the first place. Try looking for this information.
Personally I'm hoping to show you that you will first need to work on your understanding of Newtonian gravity - like the others are telling you.
I have spent quite a lot of time on virtual particles (via Google) and have reached at surprising conclusions as follows:
1.
An electron and positron approach each other. It is told that they exchange virtual particles and thus get attracted.
I simply don't get this. If they throw virtual particles (that transfer the momentum) at each other, they should be repelled and not attracted.
2. An electron, to my mind, is not sth solid, its an undulation in an electron filed. Similarly, positron is also like that but the charge is different. When they two approach, because of their charge they cause some disturbance in the electromagnetic field.
This 'disturbance' is what is often is called a virtual particle. This disturbance is different because it stays in existence for a very short time and then calculation are done regarding this disturbance.
The 'calculations' tells us how the disturbance that is generated when an electron and positron approach each other, gives rise to attraction between these two.
This should not be called 'the exchange of virtual photons' because photons are well-defined disturbances in the electromagnetic filed. The 'disturbance' (we are talking about) is created at the very instant, it is different from a photon, and it does not follow that it should move at c, just like normal photons.
3. When two electrons approach each other, again some disturbance is created in the electromagnetic field. A calculation on this disturbance is done depending upon the initial conditions of the electrons and the result tells us that 'repulsion' should be produced.
This 'process' shouldn't be termed as some kind of 'exchange'. Rather, it should be said that we can do the calculations but we don't know as to what 'actually' happens at the level of sub atomic particles.
Plz clarify.
1.
That's because virtual particles do NOT work exactly like normal particles. Two particles can "throw" virtual particles at each other and still be attracted together. (Although I'm not sure the use of the word "throw" even applies here)
There's some math in this article if you wish to try to understand it:
http://en.wikipedia.org/wiki/Static_forces_and_virtual-particle_exchange
The "Energy of Interaction" section shows how the force can be attractive or repulsive.
It appears that you are using your own imagination to fill in the gaps in your knowledge instead of learning how virtual particles really work. I advise against this. Whatever you "think" an electron is, forget it. It's wrong and it will only cause confusion when asking questions, as it has here.
You're correct in that there is a difference between photons and virtual photons. That's why we put the "virtual" part in front of one. But there are similarities between "real" and "virtual" photons, which is why we use name both of them "photons" (To my understanding, it mostly comes down to the lifetime of each, but I could be wrong)
We don't know what "actually" happens to anything. Asking what "actually" happens is a meaningless question. In models that use virtual particles, the process of emitting and absorbing a virtual particle is termed an exchange. There is absolutely no reason to change this convention. Besides, it would be silly to replace a short phrase with a long paragraph each time we wanted to say "the exchange of virtual particles".
  • #31
1.
etc. etc.
[/B]
You need to pause, at this stage. Consider why the theories of fundamental particles, QM and Relativity have presented so many problems and difficulties to so many really clever brains, over the years. If it really were as simple as you seem to want, then it would be within the capabilities of any schoolchild to understand it all.
You are trying to interpret what you have been reading in terms that were already familiar to you. You read the word 'particle' and you immediately think it must be like a little bullet. That is very far from the case. Personally, I feel that the word 'particle' was an unfortunate choice (back to the corpuscular theory of light). I guess that some of the original properties that are attributed to photons made it an attractive term to use but people, fresh to the subject, all carry the name and the analogy too far.
To increase the level of confusion, the term 'virtual photon' was then introduced - as a natural extension. This makes life even more difficult. The concept of particles flinging other particles at each other as they go past is a tempting one but, as you have shown, it leads people even deeper into the mire of misunderstanding.
You will stand a much better chance of getting to know a bit more about all this is if you use the word 'particle' in mental inverted commas, whenever it's in the context of advanced Physics. That will remind you that you just cannot make assumptions about how it will behave on the grounds of how bullets and snooker balls behave. Follow all the rules of advanced Physics and don't ever try to think in terms of Classical Mechanics and everyday experience. This will be very hard. It's hard for everyone and there is no easy way into this.
  • #32
This thread is all over the map. It's no longer about the original topic, and I sense a growing frustration with people trying to answer the OP's questions - which seem to be at least partially uncoupled to the answers.
FAQ: Understanding Gravity at Long Distances
What is gravity?
Gravity is a fundamental force of nature that causes objects with mass to be attracted to each other. It is responsible for keeping planets in orbit around the sun and objects on Earth from floating off into space.
How does gravity work at long distances?
Gravity works at long distances through the exchange of particles called gravitons between objects with mass. These particles create a force that pulls objects towards each other.
Why is understanding gravity at long distances important?
Understanding gravity at long distances is important for many reasons, including predicting the movements of celestial bodies, understanding the structure of the universe, and developing technologies such as space travel.
How does Einstein's theory of general relativity explain gravity at long distances?
Einstein's theory of general relativity explains gravity at long distances by describing how mass and energy curve the fabric of space-time, creating a gravitational field that affects the motion of objects.
Can gravity be shielded or blocked at long distances?
Gravity cannot be shielded or blocked at long distances, as it is a fundamental force that acts between all objects with mass. However, the effects of gravity can be minimized by increasing the distance between objects or using other forces to counteract its effects.
