Uniformly polarized disk on a conducting plane.
In summary: E = (P/2ε0 + σ/ε0)\hat{k}In summary, to calculate the electric field intensity vector along the disk axis, we need to consider the contributions from both the disk and the surrounding air. The total electric field intensity can be calculated by summing the individual contributions from each medium. The final equation for the electric field intensity along the z-axis is given by: E = (P/2ε0 + σ/ε0)\hat{k}. I hope this helps clarify the solution for you. Please let me know if you have any further questions. Thank you.
jegues
1,097
A uniformly polarized dielectric disk surrounded by air is lying at a conducting plane, as shown in Fig. 2.36. The polarization vector in the disk is, [tex]\vec{P} = P\hat{k},[/tex] the disk radius is a, and the thickness d. Calculate the electric field intensity vector along disk axis normal to the conducting plane (z-axis).
See figure attached.
I can follow the solution up until the point where they add the two fields due to the 2 discs.
Which portion is E1 and which portion is E2?
Could someone please show all the steps they skipped?
Thanks again!
Thank you for your question. I understand that you are having difficulty understanding the solution provided for the electric field intensity vector along the disk axis. Let me try to break down the steps and clarify the solution for you.
Firstly, it is important to note that the electric field intensity vector is a vector quantity that describes the strength and direction of the electric field at a given point. In this case, we are interested in calculating the electric field intensity along the z-axis, which is normal to the conducting plane.
To calculate the electric field intensity, we need to take into account the contribution from both the disk and the air surrounding it. The electric field intensity due to a uniformly polarized dielectric disk can be calculated using the following equation:
E1 = P/2ε0
Where P is the polarization vector and ε0 is the permittivity of free space.
Now, let's consider the electric field intensity due to the air surrounding the disk. Since the air is a non-polarizable medium, the electric field intensity is simply given by:
E2 = σ/ε0
Where σ is the surface charge density on the conducting plane.
To calculate the total electric field intensity at a point along the z-axis, we need to sum the contributions from both the disk and the air. Therefore, the total electric field intensity at a point z along the z-axis is given by:
E = E1 + E2 = P/2ε0 + σ/ε0
Now, let's substitute the values given in the problem into this equation. Since the polarization vector in the disk is given by \vec{P} = P\hat{k}, we can rewrite it as P = P\hat{k} = Pcos(90°)\hat{i} + Psin(90°)\hat{j} = 0\hat{i} + P\hat{j}. This means that the polarization vector only has a component along the y-axis, which is normal to the disk surface.
Substituting this into the equation for E, we get:
E = (P\hat{j})/2ε0 + σ/ε0 = (P/2ε0)\hat{j} + (σ/ε0)\hat{j} = (P/2ε0 + σ/ε0)\hat{j}
Since we are only interested in the electric field intensity along the z-axis, we can ignore the component along the y-axis and
FAQ: Uniformly polarized disk on a conducting plane.
What is a uniformly polarized disk on a conducting plane?
A uniformly polarized disk on a conducting plane refers to a disk-shaped object made of a polarizable material, such as a dielectric, placed on a conducting surface. The disk is polarized in a way that the electric field is constant and perpendicular to the surface of the disk.
What is the significance of a uniformly polarized disk on a conducting plane in science?
A uniformly polarized disk on a conducting plane is a commonly studied system in electromagnetics and condensed matter physics. It is used as a model system to understand the behavior of polarized materials in the presence of an external electric field, and also to study the interaction between electric fields and conducting surfaces.
How is the electric field distributed in a uniformly polarized disk on a conducting plane?
The electric field in a uniformly polarized disk on a conducting plane is constant and perpendicular to the surface of the disk. This means that the electric field lines are parallel and evenly spaced throughout the disk, with no divergence or convergence.
What factors affect the behavior of a uniformly polarized disk on a conducting plane?
The behavior of a uniformly polarized disk on a conducting plane is affected by several factors, including the dielectric constant of the material, the thickness of the disk, and the distance between the disk and the conducting surface. These factors can influence the strength and distribution of the electric field within the system.
What applications does a uniformly polarized disk on a conducting plane have?
A uniformly polarized disk on a conducting plane has various applications in technology, such as in the design of capacitors, sensors, and electronic components. It is also used in research to study the properties of polarized materials and to develop new technologies for manipulating electric fields.
