Universal morphism to forgetful functor Ring->Ab
  • Thread starter grief
  • Tags
    Universal
In summary, the problem is to find a universal morphism from the forgetful functor Ring->Ab taking each ring to its underlying additive group. The answer may be the integral monoid ring, but I'm not sure how to solve it. Taking an abelian group M, we put a ring structure on it and construct a map from M\times M to R. The left adjoint to the forgetful functor is the morphism that preserves colimits. Finally, to find T(A), we need to compute the polynomial ring on the disjoint union of the variables and the group on the right is (naturally isomorphic to) the elements of R.
grief
73
I'm reading a book on category theory and I'm stuck on this problem:
For a given abelian group, what is the universal morphism to the forgetful functor Ring->Ab taking each ring to its underlying additive group?
I think if the functor was Ring -> Monoid taking each ring to the underlying multiplicative monoid, the answer would have been the integral monoid ring. But as it is, I have no idea how to solve it.
Take an abelian group M, we wish to put a ring structure on it.
Obviously, M is a [tex]\mathbb{Z}[/tex]-module. Put [tex]\mathcal{T}^0(M)=\mathbb{Z}[/tex] and
[tex]\mathcal{T}^k=M\otimes_\mathbb{Z}...\otimes_\mathbb{Z} M~\text{(k factors)}[/tex].
Now we put [tex]\mathcal{T}(M)=\oplus_{k\geq 0}{\mathcal{T}^k(M)}[/tex]. This is a ring with multiplication given by
[tex](m_1\otimes...\otimes m_i)(m^\prime_1\otimes...\otimes m^\prime_j)=(m_1\otimes...\otimes m_i\otimes m^\prime_1\otimes...\otimes m^\prime_j)[/tex]
I'll leave the universal property to you...
Thanks for the reply!
Though I'm still having trouble with the universality part.
I need to decide two things: the morphism of abelian groups from M to [tex]\mathcal{T}(M)[/tex], and, given a morphism f of abelian groups from M to a ring R, a morphism of rings from [tex]\mathcal{T}(M)[/tex] to R making the standard diagram commute.
For the former morphism, I thought of injection into the [tex]\mathcal{T}^1[/tex] coordinate of [tex]\mathcal{T}(M)[/tex]. This seems like the natural choice.
Now I'm not sure about the morphism from [tex]\mathcal{T}(M)[/tex] to R. In order to make the diagram commute, we must take an m in the [tex]\mathcal{T}^1[/tex] coordinate to f(m). But in order to make this a ring homomorphism, that means we must take m1m2 (in the [tex]\mathcal{T}^2[/tex] coordinate) to f(m1)f(m2). But this seems to not be additive-- m1m2+m3m4=(m1+m3)(m2+m4) will be taken to f(m1+m3)f(m2+m4), which does not equal f(m1)f(m2)+f(m3)f(m4).
Is there a better choice of morphism I'm not thinking about, or did I misunderstand your construction?
You wrote [tex]m_1m_2+m_3m_4=(m_1+m_3)(m_2+m_4)[/tex]. I don't really see that...
What you do is constructe the following map [tex]M\times M\rightarrow R:(m_1,m_2,...,m_n)\rightarrow m_1m_2...m_n[/tex], this is a bilinear map. From the universal property of the tensor product, we get a map [tex]\mathcal{T}^n(M)\rightarrow R[/tex].
Taking all those maps together yields a map [tex]\mathcal{T}(M)\rightarrow R[/tex]. And this is the map you want...
It turns out this is a fairly direct calculation. :smile:
You're looking for the left adjoint to the forgetful functor. Simply because it's a left adjoint, it must preserve colimits.
Furthermore, every abelian group is the colimit of copies of Z.
So we only need to figure out T(Z) and then compute colimits.
(Try computing it yourself at this point)
To compute T(Z), we hvae the formula:
HomRing(TZ, R) ~ HomAb(Z, R)​
The group on the right is (naturally isomorphic to) the elements of R. So the left set as well -- therefore TZ must be the polynomial ring Z[x].
Any presentation of an abelian group A is the same thing as writing the group as a colimit, since it let's you write A as the quotient of a free abelian group by a free abelian group.
The coproduct of polynomial rings is the polynomial ring on the disjoint union of the variables. Can you now write down a presentation for T(A)?
FAQ: Universal morphism to forgetful functor Ring->Ab
What is a universal morphism?
A universal morphism is a type of morphism or mapping between two objects in a category that has a special property. It is the most general morphism that satisfies a certain property and can be used to define other morphisms between these objects.
What is the forgetful functor Ring->Ab?
The forgetful functor Ring->Ab is a functor that maps the category of rings to the category of abelian groups. It "forgets" the ring structure and only considers the underlying abelian group structure of the ring.
How is a universal morphism related to the forgetful functor Ring->Ab?
A universal morphism to the forgetful functor Ring->Ab is a type of universal morphism that maps from a ring to an abelian group in such a way that the ring structure is "forgotten" and only the underlying abelian group structure is preserved.
What is the significance of the universal morphism to forgetful functor Ring->Ab?
The universal morphism to forgetful functor Ring->Ab is significant because it allows us to study the properties of rings by considering their underlying abelian group structures. This can simplify the analysis of certain mathematical problems and make it easier to compare different rings.
Can a universal morphism to forgetful functor Ring->Ab exist for every ring?
No, not every ring has a universal morphism to forgetful functor Ring->Ab. In order for this to exist, the underlying abelian group of the ring must have a specific property that allows for this type of mapping. This property is known as being "free" and not all rings have it.
