Use the Definition of a Limit to Find a Complex Limit (z->i)
In summary: No, it doesn't work this way with complex numbers, since you can't compare complex numbers using < or >. For instance, if |z| < 1, all that means is that z is a complex number inside the unit circle with center at the origin.You're right. Thanks for clearing that up for me.In summary, using the epsilon-delta proof, the lim(z->i) of [z^2+(1+i)z+2] is z-i. The Attempt at a Solution is to find a delta>0 such that |(z^2+(1+i)z+2)-(i)|<epsilon whenever 0<|z-i|
MelissaJL
50
The lim(z->i) of [z^2+(1+i)z+2] using the epsilon-delta proof.
z=x+iy
Triangle Inequality: |z+w|<or=|z|+|w|
For every epsilon>0, there exists a delta>0 such that
|(z^2+(1+i)z+2)-(i)|<epsilon whenever 0<|z-i|<delta
I'm not sure how to change z^2+(1+i)z+2 into z-i. Or am I approaching the situation wrong?
z=x+iy
I think you're on the right track. z2 + (1 + i)z + 2 - i factors into (z - i)(z + 1 + 2i). I came up with this by long division.
When I try the long division I get a remainder of i. Is that okay? I haven't ever done long division with complex numbers.
Are you dividing ##z^2+(1+i)z+2## by ##z-i##? Mark divided ##z^2+(1+i)z+2-i## by ##z-i##.
z=x+iy
Substitute ##z = i + t## into the original expression ##f(z) = z^2 + (1+i) z + 2## and expand it all out to get a new, equivalent, expression ##q(t)##. Now take ##t \to 0##. Believe me when I tell you it is much easier that way.
Ahh I see what I did wrong with the long division. I definitely forgot that -i in there. So now I have:
|(z+i)(z+1+2i)|<epsilon for 0<|z-i|<delta
|z+i||z+1+2i|<epsilon but what can I do with z+1+2i to isolate z+1?
No. You should have (z - i) as one of the factors, not (z + i). For the other factor, you'll need to establish some bounds on it.
Oh sorry that was a typo. I'm very dyslexic. On my paper I have it written down as |z-i||z+1+2i|<epsilon
What do you mean by bounds on it?
trying the modulus wouldn't do anything for me right now since I still have that pesky z there in z+1+2i, can I expand z out as z=a+ib?
You might want to review how you did this kind of problem when you were working with real functions. How did you find a bound when doing those limits?
You want to establish the largest and smallest values it (|z + 1 + 2i|) can have.
That's no help because you would be trading one unknown, z, for two unknowns, a and b.
Oh like making an upper or lower bound on it by taking one of the factors to be less than 1 then plugging it back into the other inequality??
Something like that. vela's recommendation to review some similar limits with real-valued function is good advice.
BTW, this thread is probably a better fit in the Calc section, so I moved it.
Oh okay, thank you. So if I want to make an upper bound I first want to take 0<|z+1+2i|<1 but by definition of absolute value it turns into -1<z+1+2i<1 and if I want to take this and make it z-i I have to add -i-1-2i to each side which gives -i-2-2i<z-i<-i-2i. So |z-i|<-i-2i
Why don't you try out the suggestion I made in Post #5?
Ray, I don't see how this is helpful. Melissa already has the limit (which is i), and now she needs to prove that this is the limit using a delta-epsilon proof.
My professor wants us to follow the definition the way he defined it in class but never gives us any examples. How do you put bounds on complex numbers then? Does anyone have any good resources for Complex Analysis? All I have for a textbook is that old Ian Stewart and David Tall's Complex Analysis: Hitchhikers guide to the plane. There's no examples in it either and the practice questions don't have answers. I never know if I'm doing anything right and clearly I'm not.
It's a lot neater and cleaner in the new representation---or at least, I think it is. What I really want to get across to Melissa is that sometimes it is simpler and more "insightful" to change variables in some way. I personally always find it easier to do epsilon-delta on polynomials about 0 than about some non-zero point, but maybe Melissa won't.
At this point I could just really use some good resources for me to be an autodidact about this course. Any online books, Youtube users, websites with good solid examples and explanations.
If I were to make a new thread later on finding resources, what category should I put it under?
I think here (https://www.physicsforums.com/forums/math-learning-materials.178/ ) would be a good choice.
You can put a bound on the distance between complex numbers. You can't say z>w, but it's perfectly fine to say |z|>|w| because the modulus of a complex number is a real number.
Write |z+1+2i| = |(z-i) + (1+3i)| and then use the triangle inequality.
FAQ: Use the Definition of a Limit to Find a Complex Limit (z->i)
What is the definition of a limit?
The definition of a limit is the value that a function approaches as the input approaches a given point. It is denoted by the notation lim(x->a) f(x) and is calculated by evaluating the function at values closer and closer to the given point.
How do you use the definition of a limit to find a complex limit?
To use the definition of a limit to find a complex limit, we first rewrite the given function in the form f(z) = u(x,y) + iv(x,y), where u and v are real-valued functions of x and y. Then, we evaluate the limit separately for the real and imaginary parts, and if both limits exist, the complex limit exists as well and is equal to the combination of the two real limits.
What is the difference between a real limit and a complex limit?
A real limit refers to the limit of a real-valued function as the input approaches a real number, while a complex limit refers to the limit of a complex-valued function as the input approaches a complex number. In other words, a real limit is a limit in one dimension, while a complex limit is a limit in two dimensions.
Are there any special cases when using the definition of a limit to find a complex limit?
Yes, there are two special cases to consider when using the definition of a limit to find a complex limit. The first is the case where the real and imaginary parts of the function do not exist separately, but the limit of the function itself exists. The second is the case where the real and imaginary limits exist, but their combination does not exist.
Can the definition of a limit be used to find limits at infinity?
Yes, the definition of a limit can be extended to find limits at infinity. In this case, the input approaches a large value instead of a specific point, and the limit is evaluated by seeing how the function behaves as the input gets larger and larger. This is known as a one-sided limit, where the input only approaches the given point from one direction.
