Using lagrange mutilpliers when lamda has two values
  • Thread starter hivesaeed4
  • Tags
    Lagrange
In summary, the problem involves finding the minimum and maximum values of a function subject to a constraint. The problem can be simplified by assuming that the variables x and y are not equal to zero. The derivative of the function can then be calculated using the partial derivatives. The function can then be solved for the two variables using the linked and free variables.
hivesaeed4
217
Consider $${f (x, y) = x^2 + 2 y^2}$$ subject to the constraint $${x^2 + y^2 = 1}$$.
What would be the minimun and the maximum values of the f.
Trouble is when I tried solving the problem lamda comes out to have two values 1 and 2 respectively. How do I proceed in order to get the answers?
Two points:
1) You get two different values for lambda only if you assume [itex]\,\,xy\neq 0\,\,[/itex] . Drop this assumption.
2) Why Lagrange, anyway? You can do way easier, imo: [tex]x^2+y^2=1\Longrightarrow x^2=1-y^2\Longrightarrow f(x,y)=(1-y^2)+2y^2=y^2+1[/tex] and this last is an easy to check 1-variable function...!
DonAntonio
Thing is that I'm required to solve it using Lagrange multipliers.
Now, I'm confused about you saying that drop the assumption xy≠0.
Could you do me a favour and show your working. I reached the point where we get two values of lamda but after that am clueless.
Some people around here think I answer too much, or do homework, for some people. In your case I feel the same since you've
been asking a lot lately...
Anyway, I can show you a little, I guess: if you define [itex]\,\,H(x,y,\lambda):= x^2+2y^2-\lambda(x^2+y^2-1)\,\,[/itex] and calculate the partial derivatives, you get:
[itex]H_x=0\Longleftrightarrow x=\lambda x\Longrightarrow \,\,[/itex] either [itex]\,\,x=0\,,\,\,\,any\,\, \lambda\,\,[/itex] , or else [itex]\,\,x\neq 0\,\,,\,\,\lambda=1[/itex] ...
The same, of course, is for for the partial in y and etc.
DonAntonio
The reason I'm asking a lot lately is that I've got my calculus-II final exam coming up in a few days and currently am more than a little worried about it. Anyway thanks about the post.
P.s. "Some people around here think I answer too much, or do homework, for some people."
Just so you know, I sincerely appreciate all that you do.
Any value of [itex]\lambda[/itex] is not relevant to the solution and you should not even bother to evaluate it! The way I would do this is note that
[tex]\nabla x^2+ 2y^2= \lambda\nabla x^2+ y^2[/tex]
[tex]2x\vec{i}+ 4y\vec{j}= 2\lambda x\vec{i}+ 2\lambda y\vec{j}[/tex]
so that we have the two equations
[tex]2x= 2\lambda x[/tex]
[tex]4y= 2\lambda y[/tex]
Because a specific value of [itex]\lambda[/itex] is not a part of the solution, eliminate it first by dividing the first equation by the second:
[tex]\frac{2x}{4y}= \frac{2\lambda x}{2\lambda y}[/tex]
[tex]\frac{x}{2y}= \frac{x}{y}[/tex]
xy= 2xy which is equivalent to xy= 0. Either x= 0 or y= 0. If x= 0, [itex]x^2+ y^2= y^2= 1[/itex] so [itex]y= \pm 1[/itex]. If y= 0, [itex]x^2= 1[/itex] so [itex]x=\pm 1[/itex]. The four solutions are (0, 1), (0, -1), (1, 0), and (-1, 0).
The division is only valid in the first place if [itex]y \neq 0[/itex], so the y = 0 solution doesn't follow from that method directly. One then either has to divide the y equation by the x equation to find that or just work with the original system of equations.
You just have to check that each solution satisfies the original constraint, and all four do. The two x=0 solutions are equal maximums and the two y=0 solutions are equal minimums. This is an easy problem to check visually if you can picture it.
hi
am pretty new to lamdba calculus and would need some help.
would anyone be able to help me on how to find the linked and free variables in the following terms..
M1 = lambda x.(f(x x))
M2 = lambda f.(M1 M1)
M3 = (M2 lambda y.x)
Thanks.
FAQ: Using lagrange mutilpliers when lamda has two values
What are Lagrange multipliers?
Lagrange multipliers are mathematical tools used in optimization problems to find the maximum or minimum value of a function subject to a set of constraints.
When should Lagrange multipliers be used?
Lagrange multipliers should be used when solving optimization problems with equality constraints, where the objective is to maximize or minimize a function while satisfying all the constraints.
What are the two values of lambda in Lagrange multipliers?
The two values of lambda in Lagrange multipliers represent the partial derivatives of the objective function with respect to each constraint variable.
How do you solve for the two values of lambda in Lagrange multipliers?
To solve for the two values of lambda, you first need to set up the Lagrangian function by adding the two values of lambda multiplied by the constraints to the objective function. Then, you find the partial derivatives of the Lagrangian with respect to each variable and set them equal to zero. Finally, you solve for the two values of lambda using algebraic manipulation.
Can Lagrange multipliers be used for problems with more than two constraints?
Yes, Lagrange multipliers can be used for problems with any number of constraints. The number of values of lambda would depend on the number of constraints in the problem.
