Vf^2=Vi^2+2ad not proportional?
In summary, an object dropped from rest will travel at a constant velocity until it reaches the ground. After that point, the object's velocity will be inversely proportional to the height from which it was dropped.
KAaron
<Moderator's note: Moved from a technical forum and thus no template.>
Hi, I am a junior in high school and future physicist. I have a problem (I am very curious) and would like for it to be solved as I CAN NOT figure this out!
I was thinking about an object being dropped from rest from my aprox. height (2m) and its acceleration.
Using the formula in the title:
Vf^2=0^2+2*9.8*2=39.2
Sqrt(39.2)=6.26
Vf ~= 6.26m/s
Now I thought about the same object dropped from half the height. You would think, or at least I did, mathmatically you would do 6.26/2 which would be 3.13.
However, if you use the same formula the answer isn't the same.
Vf^2 = 0^2+2*9.8*1=19.6
Sqrt(19.6)=4.42
Vf ~= 4.42m/s
Why does it do this?
Why?
jtbell said:
Why?
Because algebraically nothing changed but an independent variable.
Thinking about this though, if I imagine a graph, I would imagine the line to be one similar to a quadratic equation graphed. I'm not sure if that plays into this however.
What is the implicit assumption when you believe that the object will be traveling at half the velocity over half the distance? Is that assumption valid in this case?
The assumption was the rate is constant and therefor directly proportional. It is invalid, but why? It would makes sense for it to be in my head from what I have learned previously in math.
Which rate? Can you be more specific as to what is changing with respect to what?
The rate of acceleration.
If the Vi stays 0, and the acceleration is assuned as 9.8m/s^2 because I am on Earth, why would the Vf for 2meters not be divisible by 2 for the Vf for 1m?
You did not answer my question. Yes, the acceleration is a rate and yes this rate is constant. However, a rate is how fast something is changing with respect to something else. In the case of acceleration what is the "something" and what is the "something else"? If you can answer the question, you should be able to see why your approach is incorrect.
Acceleration is the increase in velocity in a given time. It is not the increase in velocity in a given distance.
There is no point in using 'words' in this argument because Maths is a much better way of describing what goes on. You have to believe that the Gravitational Potential Energy is transferred to Kinetic Energy at the end of the drop. So:
mgh = mv2/2
So, if you double the height of the drop, the Kinetic Energy doubles but the velocity increases by a factor of √2
Likes Douglas Sunday, KAaron and FactChecker
mgh = mv2/2
I see. Thank you. We just started learning Ep and Ek this week actually so that didn't even occur to me. I want to be a physicist when I graduate and I like thinking of these types of questions that really make me think.
What you are thinking of is a linear transformation. If the kinematic equations were linear, then sure you would see this, but that is not the case. They are parabolic and significantly different.
Me too, physics is what I want in my future. I often find that the key to all of these questions is looking carefully at the language of physics, math. And of course practicing so much that the concept is absolutely imprinted on your mind.
A very practical use of this is to note that some "driver's ed." courses emphasize the fact that when you double your speed it requires four times the distance to come to a stop. That is one good reason to not "tailgate", especially at highway speeds.
Likes kuruman
Very good point.
I'm glad yours did, my drivers ed course was a joke. My friend didn't even know how to turn her highbeams on after she got her license. I was very dissapointed.
Related to Vf^2=Vi^2+2ad not proportional?
1. What does the equation Vf^2=Vi^2+2ad not proportional represent?
The equation Vf^2=Vi^2+2ad not proportional is a mathematical expression that represents the relationship between velocity, acceleration, and displacement in a non-proportional manner. It is often used to calculate the final velocity of an object after a certain amount of time, given its initial velocity, acceleration, and displacement.
2. How is the equation Vf^2=Vi^2+2ad not proportional derived?
The equation Vf^2=Vi^2+2ad not proportional is derived from the equations of motion, specifically the kinematic equations. It is a combination of the equations for velocity and displacement, and is modified to account for the non-proportional relationship between these variables.
3. Can this equation be used for any type of motion?
Yes, this equation can be used for any type of motion, as long as the acceleration remains constant. It is a general equation that applies to both linear and rotational motion.
4. What is the significance of the constant "2" in the equation Vf^2=Vi^2+2ad not proportional?
The constant "2" in the equation Vf^2=Vi^2+2ad not proportional represents the fact that the relationship between velocity, acceleration, and displacement is not proportional. In other words, the change in velocity is not directly proportional to the change in displacement, and the constant "2" takes this into account.
5. How does this equation relate to Newton's second law of motion?
The equation Vf^2=Vi^2+2ad not proportional is derived from Newton's second law of motion, which states that the net force acting on an object is equal to its mass times its acceleration (F=ma). By rearranging this equation, we can get a=F/m, and substituting this into the original kinematic equation for velocity (Vf=Vi+at), we get Vf^2=Vi^2+2ad not proportional.
