Wanna ask bout dimensional analysis
In summary: That would give you an approximate diameter for the compressed Earth.In summary, dimensional analysis can lead you to the general form of a physical quantity, but it cannot determine the numerical value of constants. The entire matter of the Earth, if all space was removed so just matter remained, would have a compressed volume and diameter determined by the average density of the Earth and the density of nuclear matter. The exact number of atoms in the Earth is unknown and would depend on the size of the atoms, which is approximately 10^-15 m for protons and neutrons.
pcfighter
any body know...
question:
true or false??
dimensional analysis can give you the numerical value of constants of propotionality that may appear in a algebra system...
and can u give the reason too...??
False. Dimensional analysis can tell you what units you need and lead you to the general form but cannot tell you what the numerical value of constants must be.
An example of this would be finding the area of a plane figure by dimensional analysis. Area has units of square meters (m^2) [or square inches, or whatever length units you prefer]. So the simplest possible expression for the area is A = L^2 .
But what shape is this? As far as dimensional analysis is concerned, it doesn't matter: any plane figure will have an area given by the product of two lengths. A specific shape will have an area which includes a "dimensionless" constant related to the shape. (Also, the shape may have an area involving a product of two distinct lengths.)
So you can have
square: [tex]A = 1 \cdot x^2[/tex]
rectangle: [tex]A = 1 \cdot xy [/tex]
triangle: [tex]A = \frac{1}{2}bh[/tex]
circle: [tex]A = \pi R^2[/tex]
ellipse: [tex]A = \pi ab[/tex]
It will be much the same in dealing with any physical quantity by dimensional analysis.
how big would the entire matter of the Earth be if all space was removed so just matter remained??
there are approximately, 133,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000 atoms that comprise earth, but i don't know enough of atomical dimensions(how much of a proton/neutron etc are comprised of space??), to work this out.
First off, a tip: new questions, especially if they're unrelated to the original question starting the thread, should be asked by starting a new thread.
Here's a quick way to find an estimate. You can take the mass of the Earth and divide it by the volume of the Earth (volume of a sphere with Earth's radius) to get an average density for the Earth. The typical density of nuclear matter (just protons and neutrons with "no space between" -- and the electrons hardly count...) is around 10^14 gm/(cm^3). So the volume of the "compressed Earth" would be given by
Compressed volume / Volume of Earth = average density of Earth / density of nuclear matter .
That would give you the volume of the ball of protons and neutrons. If you want to find its radius, solve the equation for the volume of this sphere for the new radius.
I haven't checked your number of atoms, but the approximate diameter of a nucleon (proton or neutron) is about 10^-15 m.
FAQ: Wanna ask bout dimensional analysis
What is dimensional analysis?
Dimensional analysis is a mathematical method used to convert between different units of measurement. It involves using conversion factors and canceling out units to ensure that the end result has the desired units.
Why is dimensional analysis important?
Dimensional analysis is important because it allows us to easily convert between different units of measurement without having to memorize complex conversion formulas. It also helps ensure that our calculations are accurate and have the correct units.
How do I perform dimensional analysis?
To perform dimensional analysis, you first need to identify the units you are starting with and the units you want to end up with. Then, you can use conversion factors to cancel out unwanted units and end up with the desired units.
Can dimensional analysis be used for all types of units?
Yes, dimensional analysis can be used for all types of units as long as the units being converted are compatible with each other. For example, you can use dimensional analysis to convert between units of length, mass, time, temperature, etc.
How do I know if I have performed dimensional analysis correctly?
If you have performed dimensional analysis correctly, the final answer should have the desired units. Additionally, all of the units should have cancelled out except for the desired units, leaving you with a numerical value and the desired units.
