What do each of these variables mean? (Exponential functions)
In summary, the equation y=ab^k(x-d)+c has these variables: y, ab, k, x, and d. The y value is the base function, ab is the amplitude, k is the damping factor, c is a constant which just shifts the graph vertically and d is just a phase shift. The equation can be used to solve problems involving signals. The a value stretches the graph vertically, the d value determines if the graph will shift on the x axis (left or right), the c value determines if the graph will shift on the y axis (up or down), and the k value determines the stretches of the graph horizontally
supernova1203
210
I've been working with these problems for the past few days and although i managed to solve them all, I'm still not a 100% sure so i'd like someone to clarify for me
What do EACH of these variables mean? And on a graph what do they do?
a
b
d
c
k
in the equation y= ab^k(x-d)+c
y=ab^k(x-d)+c
for example we were given a problem y=2-3(5^x+4)...here i was having trouble determining which variable was which...untill i looked at the base function which was y=5^x and realized they are of the form y=b^x, and realized that 5 was the B value...and 2 was the C value in y=ab^k(x-d)+c they had just re arranged it to confuse me
or this one that gave me quite a bit of trouble...
y=1/5(32^x)-4..
How would one know which is which here?
i suppose -4 is the c value...and 32 is the k value? and 1/5 is the b value or a value? and the d value is 1 because there's nothing next to the x which implies a 1.
the 1/5 was the one that confused me the most i couldn't determine weather it was the a or the b value...and i'm not even sure what the b value does...
sorry if this is not the most coherent question
the a value stretches the graph vertically, and if negative reflects on the x axis
the d value determines if the graph will shift on the x axis(left or right)
the c value determines if the graph will shift on the y axis(up or down)
the k value determines the stretches of the graph horizontally and if negative reflection on the y axis...
still got no clue what the b value does...
Are you sure that 'c' is in the exponent power? From the looks of it, a seems to be the amplitude, k is the damping factor, c is a constant which just shifts the graph vertically and d is just a phase shift.
All this is with reference to signals. From pure mathematics, c remains unchanged, d just shifts the graph to the left or right, k controls how fast the graph rises, and a is the amplitude.
k determines horizontal stretch, a determines vertical stretch, d and c determine where the graph will be moved to(Although they do not determine the shape of the graph like a and k do)
d determines where it will be moved on the x-axis and c determines where it will be moved on the y axis.
supernova1203 said:
y= ab^k(x-d)+c
You mean this, right?
[tex]y = a \cdot b^{k(x - d)} + c[/tex]
supernova1203 said:
y=1/5(32^x)-4..
b, the base, is the value that is raised to x, or the expression that contains x. So b is not 1/5. a is the vertical stretch/shrink factor, as you said, and it's the number multiplied by the base. You didn't specify a value for a.
k is the number multiplied by x as part of the exponent, so k is not 32. d is the number added/subtracted from x as part of the exponent, so d is not 1.
This may be too big of a hint, but if I rewrite the function as
[tex]y = \frac{1}{5} \cdot 32^{1(x - 0)} + (-4)[/tex]
can you find the correct values now?
damnit you are right...also where did you learn tex? It's something i want to learn
[tex]
$\begin{array}{lll}
y = \frac{1}{5} \cdot 32^{1 (x - 0)} + 4 & & \grave{}
\end{array}$
[/tex]
omg... i did that! ^^ I am learning tex!
FAQ: What do each of these variables mean? (Exponential functions)
What is an exponential function?
An exponential function is a mathematical function in the form of f(x) = ab^x, where a and b are constants and x is the variable. It is characterized by a rapid increase or decrease in values as x increases, and it is commonly used to model growth and decay phenomena.
What does the variable "a" represent in an exponential function?
The variable "a" in an exponential function represents the initial value or starting point of the function. It is the value of the function at x = 0, and it determines the y-intercept of the graph.
What does the variable "b" represent in an exponential function?
The variable "b" in an exponential function represents the base or growth factor. It determines the rate at which the function increases or decreases as x increases. A base greater than 1 indicates exponential growth, while a base between 0 and 1 indicates exponential decay.
How do you interpret the graph of an exponential function?
The graph of an exponential function is a curve that starts low and increases or decreases rapidly as x increases. Its shape depends on the value of the base "b". The graph also crosses the y-axis at the point (0,a) and never touches or crosses the x-axis.
What are some real-life applications of exponential functions?
Exponential functions are commonly used in various fields such as finance, biology, and physics. Some examples include population growth, compound interest, radioactive decay, and bacterial growth. They are also used to model the spread of diseases, the depreciation of assets, and the growth of technology and social media.
