What does refractive index depend upon?
In summary, the refractive index of a material is dependent on the wavelength of light and the relative permittivity and permeability of the medium. This means that different wavelengths of light will have different refractive indices in the same material. The refractive index also determines the speed of light in the medium. The frequency of light also affects the refractive index as it is related to the permittivity, which is dependent on the frequency. Therefore, the refractive index is not solely dependent on the velocity of light in the medium, but rather on a combination of factors.
Misr
385
what does refractive index depend upon?
The answer of my textbook is "wavelength" so how,although it cannot be controlled directly??
I thought It depends on the speed of light in the media
I don't understand how to answer these kinds of questions
for example :what does the deviation angle of a prism depends upon?
[PLAIN]http://utopia.cord.org/cm/leot/course06_mod07/Fig3.gif
I thought it depends upon three factors which are :1-angle of incidence(theta1).
2-angle A and theta 4
but that's not the right answer , It depends only on theta1 or angle of incidence not the other two angles-despite the fact that we can change angle A
Another thing that is confusing me
"the minimum angle of deviation of a prism depends on the refractive index"
According to the relation
[PLAIN]http://utopia.cord.org/cm/leot/course06_mod07/image87.gif
it could depend on other factors
I'm totally confused!
May be the answer to these kind of questions is the factor which can be controlled directly
but in my first question the answer was "wavelength" although we cannot change wave lenth in a direct way
Please help me fix those misleading conceptions
hope you could understand me
Thanks very much
Science news on Phys.org
The refractive index of a material, regardless of its shape, is dependant on the wavelength of the light. It looks like your questions are assuming that the prism isn't changed at all, but the light can be.
you didn't answer my questions
Can we control the wavelength by a direct method?
why don't we say that it is dependant on the velocity of light in the medium??
n=c/v
If you are going to use that prism how you want it then you must use monochormoatic light. Lasers can put out 1 wavelength, e.g. helium-neon lasers (most popular) will spit 633nm.
Different wavelengths of light travel at different speeds through the material, so since n=c/v then the "refractive index" changes by definition depending on what wavelength you are talking about.
It would help if you used proper grammar and structure to make your questions clear. I tried very hard to understand what you were asking. I don't even see where you asked if we can control the wavelength unless the 2nd sentence is actually a question.
Anyways, you can change the wavelength of the light that enters the prism by simply using a different color. Is that what you wanted to know?
n=c/v
I believe it is because the refractive index determines the speed in the medium, not the other way around.
but how about the frequency?
Yeah.but how would this affect the refractive index if the refractive index=c\v
That's indeed a great answer.This is the kind of answer I need
It changes when wavelength changes. Do you know what frequency and wavelength represent?
From wikipedia on dispersion: In general, the refractive index is some function of the frequency f of the light, thus n = n(f), or alternatively, with respect to the wave's wavelength n = n(λ). The wavelength dependence of a material's refractive index is usually quantified by an empirical formula, the Cauchy or Sellmeier equations.
I believe that the refractive index will be slightly different for different wavelengths of light. A refraction telescope must use multiple lenses to focus the different wavelengths of light all at the same point. A single lens will have a noticeable distance between the focal points of different colors. The larger the distance between wavelengths, the longer the distance between focal points of the two colors.
Refractive index is given as;
[tex] n = \sqrt{\mu\epsilon} [/tex]
Where [itex]\epsilon[/itex] is the relative permittivity and [itex]\mu[/itex] is the relative permeability of the medium.
Permittivity is related to the electric polarizability, which is the electric dipole moment per unit volume per unit of electric field strength. Similarly, permeability is related to the magnetic polarizability, which is the magnetic dipole moment per unit volume per unit magnetic field strength.
For "ordinary" optical materials, the relative permeability is very close to 1, hence;
[tex] n = \sqrt{\epsilon} [/tex]
In general, the permittivity is a 3x3 matrix (to account for birefringent materials that have more than one principal refractive index) and each component is dependent on the frequency.
Indeed. It is the induced dipole moment per unit field (electric and magnetic) that ultimately affects the velocity of EM waves through the medium.
Claude.
FAQ: What does refractive index depend upon?
The refractive index is a measure of how much light is bent, or refracted, when it passes through a medium. It depends on several factors, including the material and the wavelength of the light.
What is the relationship between refractive index and wavelength?
The refractive index of a material varies with the wavelength of light. This is known as dispersion, and it is the reason why we see different colors when light passes through a prism.
How does temperature affect refractive index?
In general, the refractive index of a material decreases as temperature increases. This is because the molecules in the material have more energy and move around more, causing light to be refracted less.
What is the difference between absolute and relative refractive index?
The absolute refractive index is a measure of how much a material slows down light compared to a vacuum. The relative refractive index is a measure of how much a material slows down light compared to another material.
Can the refractive index of a material be changed?
Yes, the refractive index of a material can be changed by altering its physical properties, such as temperature, pressure, or composition. This is why different materials have different refractive indices, and why the refractive index of a material can vary with different wavelengths of light.
