What equations would I use to solve for work and power delivered?
  • Thread starter george256
  • Tags
    Power Work
In summary, when the particle moves from the rest position to the 2 meter position, it undergoes a force of 6 + 4x - 3x^2, which results in a work of 12J. The power delivered to the particle at this point is 20J.
george256
A 6 kg particle starts from rest at x = 0 and moves under the influence of a single force Fx = 6 + 4x - 3x2, where Fx is in Newtons and x is in meters.
(a) Find the work done by the force as the particle moves from x = 0 to x = 2 m.
in J
(b) Find the power delivered to the particle when it is at x = 2 m.
in W
How do you determine the work done on an object given a certain force acting over a certain distance? This should be a very basic equation that you should know the equation for.
Also, the units seem to be a bit odd, are you sure that's the correct form of the force?
fx is 6+4x-3x^2 sorry about that. and would i use the equation w= integral of fx from distance initial to distance final?
Yes. There you go. Your integration bounds are given the initial and final distances.
ok now do i have to integrate the fx or is that already accomplished and i should just plug in the numbers, because when i integrate that i get -x^3+2x^2+6x and when i integrate from 0 to 2 i get the answer incorrect.
No, you must integrate the function. Check your work, you integrated correctly.
and also how can i find power without a time given
For that after i integrate i get 20 is that incorrect?
No, that's not correct.
I didn't even notice the part asking about power. I really think you haven't written down the problem correctly. Are you sure you don't mean [itex]x(t) = 6 + 4t - 3t^2[/itex]?
that is the exact copy of my problem. i just looked it over and i am not sure where i am going wrong when i integrate all i should have to do is plug 2 in as x correct because 0 will just yield 0 when plugged in as x
You don't have enough information to determine the power.
When you integrate, you should get the work done = 12J, not 20J (check your algebra). I highly doubt you have copied the question correctly. There is no way to determine the power with what you are given.
that is what i thought and i just double checked that. when you integrate is it products of time inital minus time final? is that where i am making my mistake. I have not integrated in a very long time.
never mind i realize what i did wrong in integration. stupid mistake. I wish i could figure out the power though
thanks for your help. i appreciate it. i just gave up on the power. if you could not figure it out i knew it must not be possible.
FAQ: What equations would I use to solve for work and power delivered?
What is the equation for work?
The equation for work is W = Fd, where W represents work, F represents the force applied, and d represents the distance over which the force is applied.
What is the equation for power?
The equation for power is P = W/t, where P represents power, W represents work, and t represents time. This equation shows the relationship between work and time, and is often measured in watts (W).
How do I calculate work when given force and distance?
To calculate work when given force and distance, you would use the equation W = Fd. Simply multiply the force applied by the distance over which it is applied to find the work done.
How do I calculate power when given work and time?
To calculate power when given work and time, you would use the equation P = W/t. This shows the relationship between the amount of work done over a certain amount of time, and is often measured in watts (W).
What are some real-life examples of using work and power equations?
Work and power equations are used in many real-life situations, such as measuring the power output of an engine or calculating the work done by a machine. These equations are also used in physics and engineering to solve various problems involving force, distance, time, and energy.
