kartikwat
- 49
What happens when charge enters the resistor?
kartikwat said:What happens when charge enters the resistor?
Hardik Batra said:What do you mean by resistor ?
Jd0g33 said:It's like a roadblock. Some of the electron's kinetic energy is transferred to the resistor atom's thermal energy. The resistor heats up, the electrons have less energy coming out the other side. This is why it's called a voltage drop, you lose potential energy.
A resistor is an electronic component that is designed to resist the flow of electric current. It is typically made of a material with high resistance, such as carbon or metal, and is used to control the amount of current flowing through a circuit.
A resistor reduces the flow of charge by dissipating some of the energy from the electric current as heat. This reduces the current flowing through the resistor and can control the overall flow of charge in a circuit.
As the charge enters a resistor, it encounters resistance which causes it to slow down and lose energy. This energy is then dissipated as heat, and the charge continues to flow through the resistor at a reduced rate.
The resistance of a resistor is directly proportional to the amount of charge that can flow through it. This means that as the resistance increases, the flow of charge decreases, and vice versa.
Resistors are used in a wide range of electronic devices and circuits. They are commonly used to control the amount of current flowing through a circuit, to limit the current to safe levels, and to divide voltage levels. They are also used in sensors, amplifiers, and filters.
