What is the entropy change of gas during an internal combustion engine test?
In summary: I always make that mistake when dealing with these types of equations. Thanks for catching it!In summary, during the test of an internal combustion engine, 3.00 L of nitrogen gas at 18.5 C was compressed suddenly (and irreversibly) to 0.500L by driving in a piston. In the process the temperature of the gas increased to 28.1 C. Assuming ideal behavior, the change in entropy of the gas is -14.22 J/K. The formula used to calculate this is dS = c_v ln(T2/T1) + R ln(V2/V1), where c_v is the specific heat at constant volume, R is the universal gas constant, and T2
sparkle123
175
During the test of an internal combustion engine, 3.00 L of nitrogen gas at 18.5 C was compressed suddenly (and irreversibly) to 0.500L by driving in a piston. In the process the temperature of the gas increased to 28.1 C. Assume ideal behavior. What is the change in entropy of the gas?
dS=nRln(V2/V1)
dS=Cln(T2/T1)
C=5R/2
I think that you need the number of moles of gas to be able to solve this...
The answer provided is -14.6 J/K but how do you do this? Please help!
I would use your second equation, noting that the specific heat with constant pressure = 5R/2. Since R is a constant and the two temperatures are given, you can solve that without knowing n. Don't forget to convert to Kelvin, and do note that ds in your equations is not a differential change in entropy, but rather a (delta-s) change in entropy.
So I don't need to take into account the change in volume?
Thanks!
Thanks!
I don't think so, but then, I'm rusty with some of this thermo stuff.
You do need to take account of both. Since entropy is a state function, you can imagine any process from state A to state B, and the entropy change will be the same. So you can imagine first an isothermal compression from 3.0L to 0.5L, followed by a change in temperature from 18.5 to 21.8C at constant volume. When do those formulas you gave apply?
I plugged the numbers in as follows:
[tex]
c_v = 20.81 \frac{J}{K\ mol}
[/tex]
[tex]
R = 8.314472 \frac{J}{mol\ K}
[/tex]
[tex]
dS = c_v ln(\frac{T2}{T1}) + R\ ln(\frac{2}{V1}) = -14.22 \frac{J}{mol\ K}
[/tex]
The result is close to, but not the same as, the supposed solution value. The solution also seems to have mucked up the units.
A reasonable reference sheet for this stuff is http://www.grc.nasa.gov/WWW/K-12/airplane/entropy.html"
I plugged in the same values and got a different answer. In your formula, you have an "ln(2/V1)". I assume you mean ln(V2/V1) which is ln(0.5/2), right?
I think I found your error. You forgot to convert Celcius to Kelvin when you did T2/T1, didn't you? You can only use an absolute temperature any time you're dividing temperatures in thermodynamics.
Right.
FAQ: What is the entropy change of gas during an internal combustion engine test?
What is entropy change of gas?
Entropy change of gas refers to the change in the thermodynamic quantity of entropy, which measures the disorder or randomness of a gas system. It is a measure of the amount of energy that is unavailable for work during a thermodynamic process.
How is entropy change of gas calculated?
The entropy change of gas can be calculated using the formula ΔS = nRln(V2/V1), where n is the number of moles of gas, R is the gas constant, and V2 and V1 are the final and initial volumes of the gas, respectively.
What factors affect the entropy change of gas?
The entropy change of gas is affected by changes in pressure, temperature, and volume. An increase in any of these factors can lead to an increase in the disorder and therefore, an increase in entropy change.
What is the significance of entropy change of gas?
The entropy change of gas is important in understanding and predicting the behavior of gases in various thermodynamic processes. It helps to determine the direction and extent of changes in a gas system and is a key factor in determining the efficiency of heat engines.
Can the entropy change of gas be negative?
Yes, the entropy change of gas can be negative, indicating a decrease in the disorder or randomness of the gas system. This can occur in processes such as compression, where the gas becomes more ordered and its entropy decreases.
